Question about Cell Phones
I need a charger for air hogs helix race drone. where can I get this?
Helix race drone red and black
  • 7 Answers
SOURCE: My air hogs helix 360 is bobbing front and back
No this wobble is not caused by the tail motor. i have had 3 that have all done the same thing. The fix is simple. The tail would cause it to go back and forth like it is turning back and forth with rudder. When he says bobbing he is talking about a oval shaped motion that the heli does while hovering. looks like its rocking front to back. tail wag is different and has to do with gyro over sensitivity. To fix: Look at the flybar and check for even flybar paddles (if looking down the flybar make sure one is not angled differently than the other) you can twist them a little to manipulate them. #2 the small extensions connecting the flybar to the links may be bent up or down. Again, looking down the flybar make sure they are pretty level with one another (you can slightly bend them back but be gentle. #3 There is a pin connecting the flybar to the head that goes through. What happens is, after a few bang into things this can start to move out just a fraction of a mm. You will notice that the flybar can move back and forth like it should very easily but there is also a little play rocking it the other way that it is not supposed to go. this amount will be very small but plenty to adversely affect the heli. take a pair of needle nose pliers and carefulle push that pin in just a touch until the flybar tightens enough to stop the movement. Be sure its not too tight so it takes away from the easy movement the flybar is supposed to have. I 100% promise its not the tail motor.
Posted on Sep 10, 2011
riceski
  • 1851 Answers
SOURCE: I have a black and
The red light means it needs charging - some will come on while it is charging - but it should be green when fully charged.
Posted on Sep 14, 2010
  • 22 Answers
SOURCE: My air hogs sharpshooter is
mine started working!!! i just left the remote switch in the "charge" position overnight and then i put the switch all the way up the all the way down and it started charging.
Posted on Dec 14, 2010
VLAD1431
  • 12 Answers
SOURCE: air hog helix 360...flybar is
They have little pieces that push on a ring to move it around. Open the heli and check that they are all inside of the ring. ~VLAD~
Posted on Feb 21, 2011
juliann88
SOURCE: WHy is air hog battery charger flashing red
I had a Storm Launcher battery that was unused for sometime and when I plugged it in to the charger, the light flashed red. I checked the voltage of the pack and it was down around 2.5V....from 7.4V. I figured the "smart charger" thought it had a dead or shorted cell and wouldn't kick in the charging circuit. I McGyver'd the two probes and alligator clips to connect the pack to a 9V. NiCad "dumb" charger. The light came on showing a charge and I left it for 5 mins. Unhooked it and checked the voltage. It was now 5 volts...supposed to be 7.4...but much better than 2.5. Plugged the pack into the AirHogs charger and the green light started flashing, indicating a charge. Later I got the double-flashing and 10 minutes after that FULL charge! Just needed a boost to start the smart charger.
Posted on Jan 24, 2012
I bought my grandson an AirHog Helix ion.Controller is very well made but drone was poorly made and only worked three times. I can't seem to find a replacment drone PLEASE HELP
Don't try replacing the drone, try replacing the sensor on the drone that connects to the controller. That might be why it isn't working anymore, because the sensor got damaged.
Sep 25, 2016 | Toys
Air Hogs R/C pocket-copter not functioning
your copter might have already experienced some hard bumps or landings , so you might need to check your copter circuit and battery cables to make sure they are in good condition or check the battery itself.
May 02, 2015 | Spin Master 1001130 Air Hogs R/C Pocket...
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
Air hogs charger blinks red then turns off
Make sure you have the switches set properly.
Dec 28, 2012 | Air Hogs Toys
I just bought an air hog havoc stinger and the stabilizer broke. where can i get a replacement part? please help!
Found it on ebay...
http://cgi.ebay.com/Stabilizer-Blade-Balance-Bar-air-hog-Reflex-Helix-Heli-/250711651055?pt=Radio_Control_Parts_Accessories&hash=item3a5f9432ef#ht_920wt_1141
Mar 01, 2011 | Toys
Just bought an air hogs helix 360. Now when i give it throttle and let it go, it flys straight left and hits the ground. Any solutions?
It's common for this copter to lift and drift to the left. Likely caused by weight, so you can add additional weight to the opposite sides landing gear, but ultimately more weight isn't better. Sadly there is no control for this drift, you have to compensate manually to keep it perfect. ~VLAD~
Dec 30, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Does anyone know where to buy a new main prop blade for the airhog helix 360 r/c helicopter?
Look for places that distribute "Air Hog" Products in your area. They should be able to help you.
Dec 25, 2010 | Spinmaster Air Hogs Helix 360 Helicopter
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
