Question about Acer Computers & Internet
There are instructions on the packet it came in but nothing else. Use your chosen OS and browser to change what you want it to do.
Posted on Dec 29, 2016
SOURCE: acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
Posted on May 08, 2008
SOURCE: Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Posted on Aug 04, 2008
SOURCE: repair manual for Acer Aspire 5610Z
Here you go:
http://personafile.com/Acer-Notebook-Aspire-5610Z-P099802000397.htm
Happy Holidays
Posted on Dec 24, 2008
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
SOURCE: How to connect the Microsoft Wired Keyboard 500 to
ok this is slightly a common problem i come across this situation quite easily, don't worry that the problem is with your usb adapter, its that the keyboard or acer does not have the software needed to run it properly if the keyboard came with a cd get a external cd player and download the software to the computer, but if it did not come with a cd *note: i assumed you have windows xp if you do not please find a way to do this with a different OS* go to control panel, add hardware then follow the instuctions there that should help you install the keyboard so you can use it, allthough if your keyboard is so old it has a ps/2 port i sugest getting a new keyboard with usb plug and use/play they are more user freindly and you will never have this type of problem again.
Posted on Feb 08, 2010
Mar 05, 2017 | Acer Computers & Internet
Feb 24, 2015 | Acer Aspire One D255E13438 Netbook
Oct 09, 2014 | Computers & Internet
May 19, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Aug 28, 2010 | Acer Aspire One A150-1006 Notebook
Oct 17, 2009 | Acer Aspire 5735 Notebook
Sep 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Aug 22, 2008 | Acer Aspire 3004WLCi Notebook
Jul 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
Mar 08, 2008 | Acer Wireless WIL-152 91.84R07.152...
105 people viewed this question
