Question about Sewing Machines
If i run out of yarn casting on can i add stitches using provisional?
What is meaning of CO in knit pattern
Cast On. This is what you use to start your project. You basically have two needles and a piece of yarn, Casting on creates the first row of stitches.
Aug 10, 2017 | Sewing Machines
Decreasing single crochet stitches
There are several ways of decreasing crochet stitches, but the pattern should indicate what stitches to use. The most common (or easiest) is to yarn over in the first stitch (do NOT pull the rest of the stitch through) and then yarn over into the second stitch and pull the final stitch through both yarn overs.
How to Decrease Single Crochet dummies
Mar 18, 2017 | Sewing Machines
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
What do yon and yfrn mean in a knitting pattern?
yon is usually Yarn On (or over) Needle. This is a yarn over between a purl and a knit stitch. (After the purl stitch, keep the working yarn in front of the needle. Then place the right needle into the next stitch so that the right needle is behind the left needle in the stitch. Wind the yarn around the needle and pull the loop through.)
yfrn is a Yarn foward and round the needle. This is a similar yarn over to the yon but is a little larger. The difference is that the yarn over is done after a knit stitch and before a purl stitch. After the knit stitch, bring the yarn in front of the needle. Wrap the yarn anti-clockwise around the right needle so that the yarn is again at the front of the work. Place the right needle in the front of the next stitch on the left needle. Then do a normal purl stitch.
You can see some videos and still photos here: http://www.stitcharena.com/library/hand-knitting/yfwd-yfrn-yrn-and-yon/ .
I hope this helps.
Oct 22, 2016 | Sewing Machines
How do you sew an Overlock stitch using yarn?
On a serger, you can only install larger threads in the loopers--but use regular thread in the needles. You can also use a cording foot, feed the yarn through the groove in the foot and overlock the stitches over and around the yarn.
Aug 24, 2015 | Sewing Machines
How do I cast off in knitting?
Take a needle several sizes larger than the ones you have used for the knitting - so the loops will be larger and the edge looser, knit the first two stitches onto the larger needle then use the tip of the other needle to lift the first stitch over the second one and right off the needle, so it is looped over the second stitch, but is no longer on the needle.
Knit another stitch and repeat the lifting over. I f you are casting off all the stitches continue to the end of the row and then cut the yarn, pass the end of the yarn through the last stitch and draw it up.
If you are only casting off part of the row then move the last stitch onto the right size needle and continue knitting on the stitches left in the row.
Dec 03, 2014 | Sewing Machines
What does knit over previous stitches mean.
Means turn you work around and just knit on the 8stitches from the last row.
Oct 31, 2014 | Lion Brand Homespun Yarn
What does knit over mean
Read the pattern again. You may be doing short rows. Buy a more detail knitting book. If you can go to Knit and Crochet Today it's a tv show that has a website they have experts in knitting and crocheting. Sure there is a demo or someone you can ask to explain in detail. I think the show comes on Thursday in Chicago but its once a week on cable/satellite on pbs.
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
