Question about Philips Televison & Video
Philips projector tv mdl#60pp9202/17f has no power.....what to do
Lc4441 projector repair
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | Philips Lamp for Philips CBRIGHT LC4441 -...
Manual
http://esupport.sony.com/US/perl/model-find.pl?mdl=VPL%20CW125&PRODTYPE=33,32,63,71,7,102,26,80,72,44,55,84,74,27,57,61,103,89,10,35,78,48,77,29,50,39,64,41,12,58,52,81,60,73,66,101,45,76,86,62,54,67,70,68,17,2,1,88,100,82,25,28,83,59,69,49,24,104,53,79,42,22,46,13,6,85,36,3,51,9,47,38,4,34,37,43,5
Dec 30, 2009 | Sony VPL CW125 LCD Projector
Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Feb 08, 2009 | Philips Hopper SV20 Impact Multimedia...
Rear projector tv rear blue projector wont focus
Look into the top of the tube. Probably has fungus growth. Do a search. I posted that solution many times this week for that. Normally, focus don't go out on T.V's by themself. Either the tube is bad or has fungus or the screen control is bad.....but very rare will focus part fail...usually brightness/screen is at fault. Don't forget to check the green tube as well when looking. Take the back off and see if your head will fit. If not, a large mirror will do just fine. Put something on with writing displayed....easier to tell that way.
Dec 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
36 tv shuts off after few minutes
have power board checked -- sounds like a short in the transformer
Dec 10, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Whant to connect my pc to my tv
We'll need more info mate . What type of tv it is and what inputs you have.
Normally the only cable that works from a PC to a TV ( if the tv is a oldish model ) is the s-video
Apr 11, 2008 | Philips LC4731/45 LCD Projector
Philips bsure sv1 projector
try plugin a computor or dvd in so it picks up a signal.
Dec 15, 2007 | Philips bSure SV1 Multimedia Projector
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
