Question about Samsung Washing Machines
Samsung front loader washer stalls with the wash cycle with 35 minutes left. It is now cycling but clock isn't changing
BIKER T
  • 909 Answers
SOURCE: washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Posted on Jul 19, 2007
  • 30 Answers
SOURCE: NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Posted on Sep 03, 2008
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
Jun 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
FRont loader washer
try this,on next load use NO deteregent/soap.Please leave a rating.
Jun 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
