What is error code 900 - Office Equipment & Supplies
Sc 900 error code appear
You don't mention the make or model of your printer/copier, but a quick Google would indicate that it is a Ricoh machine.
I give below a link to a site which lists many models of many makes of printer and error codes. their description and cause, which will help you identify what is wiring and correct it:
Error Codes Ricoh Aficio SP4100N Code 900
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Nov 30, 2014 | Office Equipment & Supplies
HOW i get engine code for t522..i have engine code/900 rip error??? \r\nMy email address is
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
  • Turn off the printer and disconnect every cable, except for the power cord.
  • Turn on the printer and see if the error returns.
  • If the error does not return, try to print a test page from the Test Menu.
  • If the test page prints correctly, the printer
Jun 05, 2011 | Lexmark T522 Laser Printer
Hi . my copier is aficio 700 .The error is sc 900 .that relate to electical counter .I Check the connection between the NVRAM and controller. Replace the NVRAM. Replace the controller. but the error not...
Other possibilities
SC 900
[SC900] - replace fuse 8 0 4, DC power supply
SC 900
[SC900] - replace black total counter
SC 900
[SC900] - CN4 0 3 SCU PCB, poor connection
SC 900
[SC900] - replace SCU PCB, see FSM page 5 64 for rom and dip switch info
SC 900
Total counter error: Fuse #5 on PSU blown
SC 900
Total counter error: Total counter defective
SC 900
[SC900] - NV ram defective
SC 900
[SC900] - re load copier firmware
SC 900
[SC900] - replace counter harness
SC 900
Electrical counter fail - Replace Mechanical Counter
SC 900
Electronic counter error - Replace NVRAM-B098 9590.
SC 900
[SC900] - replace IOB PCB
SC 900
[SC900] - NVRAM defective
SC 900
Electrical total counter error - NVRAM data defective
Jan 28, 2011 | Ricoh Aficio 450 Copier
Error code 900 Lexmark c544dn network printer
900 errors usually point to fuser or fuser related component failure.
Please have the printer serviced.
Oct 06, 2010 | Lexmark C544dn Laser Printer
What does 900 Service RIP Software error message mean and how do i reslove it
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Aug 02, 2010 | Lexmark Optra T610 Laser Printer
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Rip software code 900
Please contact the IBM Printer Technical Support for more exact information.
A 900 RIP error means that you have a down-level firmware build on the printer. Its a software bug that was more than likely fixed in later issues of code.
Normally all you have to do is download the newest firmware build and then follow the instructions to upgrade the printer.
Nov 23, 2009 | IBM Infoprint 1612 Express Printer
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
May 04, 2009 | Dell Office Equipment & Supplies
