Question about Grilling
I can't find jam grills in bluetooth - Grilling
My jam classic wont go into pairing mode at all and my phone wont pick upat all
Make sure your Bluetooth is turned on on your phone. You may have to make it discoverable as well
Feb 09, 2015 | HMDX Audio JAM Bluetooth Wireless Speaker...
Traejer pellet grill auger jammed up
Contact Traeger customer service at for parts and installation instructions. Also check out the FAQs. There are instructions on replacing and aligning the augurs.
Mar 23, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Samsung galaxy stellar bluetooth cannot discover my Jam hdmx speaker.
Check that bluetooth is turned on, on your Samsung Phone which is likely but make sure that your phone is set as visible to all devices. Then try searching again for the bluetooth speaker.
Dec 30, 2013 | Cell Phones
Want to use a wireless speaker via bluetooth. How do u turn on the bluetooth? I push the FN, and F3 and get 'no device'. I need to 'pair' the speaker (HMDX Jam Wireless). Well, help
Does you laptop have Bluetooth? Open start menu, search, type Buletooth, Does it come up? OR, Open Device Manager, Network Adapters, is Bluetooth adapter listed? OR, Open Services, do you see Bluetooth? If you find the Bluetooth Software, open Settings.
Feb 06, 2013 | Acer Aspire One PC Notebook
Bluetooth headset with Imate K-Jam
change ur bluetooth device setting which appears in ur paired device menu ...this will work
Feb 18, 2009 | i-mate K-jam Smartphone
Reception / signal keeps cutting in and out
there is a bug with the i-mate jam bluetooth , it may cuase this  when this happend try to enable and then disable the bluetooth,
if it works agian there is a file fix this bug in the bluetooth from club i-mate site try to download it
Dec 10, 2007 | i-mate JAM Pocket PC
Imate jam PC synch
dear abid, connecting the i-mate to computer using bluetooth is a good and a fast way and give you the an option to connect more than one device, you can connect through bluetooth with this procesure : step one: set up a bluetooth COM port : 1- Open the Bluetooth Devices Control Panel. On the Options tab, select Turn discovery on and Allow Bluetooth devices to connect to this computer. 2- On the COM Ports tab, click Add. 3- Select Incoming (device initiates the connection) and click OK. 4- Note the number of the COM port that was added. The COM port number must be no higher than 20. 5- Click OK to close the Bluetooth Devices Control Panel. step two: 1- In ActiveSync on the PC, on the File menu, click Connection Settings. 2- Select Allow connections to one of the following. 3- Choose the COM Port with the number you noted in Step 1 Set up a Bluetooth COM port. 4- Click OK. Step 3 Start Bluetooth sync from your device: In ActiveSync on the device, tap Menu, then tap Connect via Bluetooth. that's all... and i am waiting for your replay
Jul 27, 2007 | i-mate JAM Pocket PC
Grilling Logo
57 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
