Question about Home
Can you remove huge burn spot from a thermacast kichen sink?
  • 4,483 Answers
Probably won't be able to remove the mark without grinding out the damaged area and repolishing though it might be possible to disguise it.
I suggest you contact the manufacturer and any specialist cleaners in your area.
Posted on Dec 28, 2016
My two week old Sanyo Mirro started to burn in my coat pocket, I quickly remove the battery...No damage was done "inside" the battery compartment, but the outside bottom right corner (phone...
I have no fix for you but my Sanyo HP700 burnt my leg and now it is infected!!! had to go to the doctor and have antibiotics and cream. There was a huge blister and it got infected in a matter of two days even tho I cleaned it and applied Polysporin triple. There is a huge red welt around the burn about a 4" diameter. partschick67@hotmail.com
Jan 17, 2011 | Sanyo Cell Phones
Small scratches and one burn spot
I'm sorry to hear someone marred this beautiful sink on you. This is essentially an acrylic sink, the same material used to make acrylic soaker tubs. Using any type of abrasive cleaner on this sink is going to dull the finish. This includes baking soda. The liquid auto polish referred to is essentially car wax not an abrasive polish. The car wax contains carnuba wax that will return a lustre to the finish but unlikely to remove the damage you've described. The manufacturer recommends using only non abrasive cleansers. There won't be anything you can do about the burn mark, this is going to be permanent. It could be from heat or possibly something caustic. If the gray scratches in the other sink look like they are on the surface of the acrylic you may be able to get them off. If it looks like the gray is underneath the acrylic finish then you will need to contact Thermocast for an acrylic repair kit for the color of your sink. Hopefully they are able to provide such an accessory. Use a plastic pan scraper and see if you can scratch the gray off the surface. The plastic is softer than the acrylic and will not scratch it. Thermocasts customer service line is 678-445-2022 or email them at sales_support@thermocastsinks.com . Their website is http://www.thermocastsinks.com/index.html
Jul 24, 2010 | International Thermocast Corp Thermocast...
Water leaked all over the floor after completing drying cycle
It is probably a clogged drain line that dumps into either your disposal if you have one or directly in the drain under your sink you may have an air gap on the sink they tend to plug around this area.
Apr 27, 2017 | Kenmore 15121 Built-in Dishwasher
I have a white Franke fireclay sink. We also have very hard water despite using an undersink filter. The sink is part of a new remodel and despite little use so far and lots of wiping, the water spots seem...
The best product I have found to remove water spots is a product called A-maz water stain remover in a 14 oz tub. There is no magic "wipe on,wipe off" product that I have found. Initially it is a little labor intensive but this is amazing stuff and can return your sink to its original luster.
This company also make a sealer but I have not tried it. A couple of alternatives might be Rain-X or Maguires auto wax. The concept here is to put a barrier down that will seal the pores of the sink and make it easier next time to remove the spots. My favorite is Maguires about every 3 months. I have provided a link below to the A-maz web site where you can find a distributor nearest you.
http://www.a-maz.com/
May 10, 2010 | Franke Double Undermount Fireclay Sink -...
Can you drill a hole for a soap dispenser in a thermacast sink
Yes you can...
Use a good sharp hole saw like you would use for wood or metal...
It is best to drill the pilot hole with just the 1/4" pilot bit before you put the hole saw on and drill the big hole. Use patience and gentle pressure and you'll be through in a minute...
heatman101
Apr 16, 2010 | International Thermocast Corp Thermocast...
White cloudy spots on my new sink
use tooth paste and lightly scub with your fingre it will be vanish
Jun 16, 2009 | Home
Water pressure very low
Sounds like the cartridge needs to be cleaned or replaced. May be clogged or faulty. This requires turning off water under the sink and pretty much taking the faucet apart.
May 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
No power
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 09, 2009 | Schumacher & Fast Charge Starter Charger
Asko washing machine has no power
check your ground fault interupters (outlets with butons) under the sink and around the kichen
then check the breakers in your breaker box
finaly call a sertified tecnition
Jan 22, 2009 | Asko W6441 Front Load Washer
Home Logo
54 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
