Question about Tablets & eReaders
Dopo dpw 20a-bt manual - Tablets & eReaders
Where can i get a owner's manual for dopo 7" quad core tablet with bluetooth keyboard
This was the only quad core I saw... If it's not the correct one then please put the model number in a response to this.
http://www.doublepowertech.com/download/m975manual.pdf
Oct 23, 2015 | Tablets & eReaders
How do I reset my 9" dopo tablet
Press to reset the tablet. Insert a paper clip or other small object with a narrow tip into this reset hole at its bottom.
25829542-zbf0iuqrbs3vw1pstdxvekqu-4-0.jpg Gopakumar Gopalan Google
Aug 20, 2015 | Double Power DOPO M-975 9" 4 GB Wi-Fi Grey...
I can't unlock my DOPO DP8856K TABLET
Not sure about Dopo but my Surface tablet has this problem at times and the solution is to press the start button at the same time as holding down the volume button. Hold for 10 seconds. Sounds weird but may be worth a try.
Feb 07, 2015 | Tablets & eReaders
Product 7in dual core tablet from dopo model dpa23d-pnk hpw do i by pass orcompletely remove the password on the main screen we cannot remember the password at all please help
as many of us learned the hard way need to write password down, and remember where it is ,I usually put it in the manual with my receipt
Jan 03, 2015 | Tablets & eReaders
My Dopo tablet want charge, what could be wrong and what can i do
1st, try unplugging and repluggin both ends. If either one is loose, it won't charge. Then, I believe the DoPo tablets use the same cable that most cell-phones use - the micro usb connector. So, if you have one of those, check to see that it is the same as the cable that came with it then, try the cell-phone charge/cable. If that don't work, you may need to return to store.
Jan 02, 2015 | Tablets & eReaders
Dopo m7088
not familiar with this brand. On Kindle I press and hold the power button for 20 seconds. Release and It flashes a few times. When it comes back up it works again. your support group is best place to start for most problems
Mar 22, 2014 | Tablets & eReaders
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
