Question about Echo ES250 Hand-held Shred N Vac
Echo es250 wont start
Fuel leaking out of carb
    Top Expert:
  • Echo Master
  • 48,419 Answers
If it has a primer bulb, replace the bulb( cracked )
Posted on Dec 28, 2016
I have a echo 330 evl it ran good till i left it set 3 years it started easy wont rev got a rebuild kit soaked in carb cleaner all nite blew it out assembled it put gas in started still wont rev
air cleaner is clean? was rebuilt ? good spark plug? is there a air / fuel adjustment screw or a high / low idle screw on the side of carb. that may be out of adjustment? fuel lines are in good shape? (not cracked or broken sucking air in)?
Jan 11, 2016 | Echo Garden
Echo blower wont fire
you sheared the flywheel key... If it's a PB250 251 or something along those lines you are going to need a new carb and flywheel. Take it to the dealer and see if they can fix in under warranty... Why the carb you say, it leaked causing the flywheel to come loose. If it's not under warranty then do not repair, you can buy a new one for about $160 USD
Dec 24, 2013 | ECHO, Inc. PB-251C Handheld Blower
Echo pe2000 edger fuel leaks from carb into engine
Fuel is leaking into the carb because the needle is being held up off the seat inside the carb or the needle is worn. Ether way requires a carb kit to be installed. About half the time the carb kit works but sometimes require a new carburetor.
Oct 29, 2013 | Echo Used Pe2000 Stick Edger Coil Assy...
Echo chainsaw 550evl wont start without pouring gas down carb
check for cracks in the fuel line also make sure the filter is still connected
Sep 06, 2012 | Echo Garden
I have an echo pb400e backpack blower. it wont start. getting fire but wont crank.
is your spark plug getting wet from fuel? try take air snorkel off carb and give it a shot of carb cleaner if it fires you have a fuel problem if it doesent fire , and plug is wet pull plug and rollover and get excess fuel out of cylinder, and try carb cleaner again, if no luck check compression, then if good go to flywheel and see if loose
Apr 12, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
My echo bp260l back pack will not crank , i can spray carb. cleaner in it. when i pull rope to crank, it runs for a few seconds
please check your muffler for blockage
check manifold gasket and carb gasket for leaking - sucking air
check for loose barrell bolts - leaking base gasket
check fuel lines and fuel filter and tank breather
pressume spark and compression are good cause it runs on prime
if everything check out
rekit carb with carb rebuild kit and reassemble
cheers paul
here is website par parts breakdown
select pb260l from list
print or save a copy
Aug 12, 2010 | Echo Garden
Gas is leaking from the leaf blower.
Unless the tank has been cracked, it has to be one of the following: Broken lines, split primer bulb, unsealed fuel cap, bowl gasket of carb. I would start with the lines and bulb since they are the ones usually at fault..Good luck...Lee
Sep 04, 2009 | Echo Garden
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 and...
Echo ES250 Hand-held Shred N Vac Logo
107 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Are you an Echo Garden Expert? Answer questions, earn points and help others
