Why is there a key flashing and machine won't switch on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
Your machine is locked. This is a handy feature for households with curious kids, but a pain for the rest of us. Without knowing your make/model i can't tell you the exact procedure to unlock. Consult your manual for unlock instructions.
Posted on Dec 29, 2016
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Xl1500 won't type lock light flashes
Try poping off the shift and shift lock key tops to see if the springsb are damaged or sticking down.
DickyO
Aug 01, 2012 | Smith Corona Typewriter XL1500 Refurbished...
2003 alero steering won't lock and nothing happens when you turn the key in the ignition
If the security light keeps flashing,you might as well do a reset.
Be sure to turn off all the accesories including the radio before you start the process.
Insert the key to the ignition switch and turn the key to ON position without starting the car.
leave it ON until the flashing light (security) stops.It will take approximately 15 to 20 minutes.
As soon the flashing stop,turn the key to OFF
position and start the cart.
Hope this help.
Jul 23, 2011 | 2003 Oldsmobile Alero
Washing machine won't go thru spin cycle. Lid lock light flashed some at first, now won't come on at all.
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Jul 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a 2006 I280 iszuzu pickup the antitheft was engaged and won't start how do I fix it?
MAKE SURE YOU USING THE RIGHT KEYS. TRY ANOTHER IGNITION KEY.PLACE KEY IN THE SWITCH. TURN IGNITION SWITCH TO ON POSITION UNTIL IMMOBILIZER WARNING LAMP ILLUMINATES FOR 2 TO 3 SECONDS. IF IMMOBILIZER WARNING LAMP ILLUMINATES FOR 2 TO 3 SECONDS THEN FLASHES RAPIDLY.KEY CODE NOT RECOGNIZED.REMOVE KEY AND TRY AGAIN. IF ALL FAILS TAKE CAR TO DEALERSHIP THEY HAVE TO USE DIAGNOSTIC EQUIPMENT TO FIX CAR.PROBLEM COULD BE IN THE IGNITION SWITCH,BCM,FAULT IN THE ECM OR IMMOBILIZER CODE INCORRECT.
Jul 04, 2011 | Isuzu i-280 Cars & Trucks
Car will not start- will crank- anti-theft light flashes - turn switch to on for 10 min. when light stops flashing - turn switch to off - then it will start. Changed to a new switch - worked or started for...
try a diffrent key,your extra one.Could be the micro-chip inside is not comunication with anti-theft-.This happened to me.I used the spare set for a few days .then the other key started working again
Jun 28, 2011 | 2004 Chevrolet Malibu
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
When I try to start car, it won't start and security light blinks. I'v e had to ignition switches put on before and I had a new key made. Car still won,t start.
If any of the gauges are blinking and going haywire and the security light flashing then the instument cluster is faulty.But if it is just the security light flashing then its in the switch.If you only had the switch replaced then you need a new ignition lock cylinder because its worn out.
May 11, 2011 | 1995 Oldsmobile Cutlass Supreme
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
