Bran new printer. All plastic is out but it says on the screen to remove plastic . And will not move on. What should I do?
Why my printer will not accept that it has new ink cartridges?
Help! What make of printer? What model of printer? Are cartridges of same make or cheaper compatibles? Please give us some information to work on. Thanks.
Dec 03, 2014 | Office Equipment & Supplies
Bran New Konica Minolta bishub c224e ADF will not work
Look for a shipping lock. Sometimes it's under the tray or such, it will move half a turn or so to release the workings. The owners manual should mention it.
Nov 25, 2013 | Konica Minolta bizhub C250 All-In-One...
I have just unpacked my HP Officejet T45 All-in-one printer (which I bought years back) and I am encountering following problem: I just removed the seal from the cartridges. It keeps saying "Insert...
hello
the seal you peel off has to be removed, so -- no , you did not do anything wrong or damage anything
and yes, after 6-9 months, ink cartridges have a an expiration date
they do not work, as the ink gets hard and canmnot be used.
buy new ink cartridges.. if its a bran new out oif the box item, just replace the consumables -- in this case the ink cartridges.
Oct 27, 2010 | HP OfficeJet t45 All-In-One InkJet Printer
Installation of cartridges correctly
Follow these steps to install the printer cartridge :
•1
Make sure the HP printer is turned on. Open the print carriage access door. Wait for the carriage to stop moving.
•2
Remove the old cartridge from the print carriage.
•3
Remove the new print cartridge from its packaging. Being careful to touch only the black plastic, gently remove the plastic tape by using the pull tabs. Make sure you've removed all of the tape.
•4
Slide the new print cartridge into the empty slot in the print carriage. Push the print cartridge forward until it clicks into place. Press down on the latch until it is securely closed.
•5
Close the print-carriage access door. Print a test page to make sure your new cartridge is properly aligned.
Oct 20, 2010 | HP Photosmart C4150 All-In-One InkJet...
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
I need to program in the new ink cartridge
Thanks for choosing fixya.com
New ink cartridges should be auto detected by your printer once installed.
To install a new cartridge depends on the specific brand/model of your printer. Most time you can (with the printer on) open the plastic door in the front and the cartridge tray will move into position. Remove the old cartridge, remove the tape or plastic protector from the bottom of the new cartridge and put it into the ink carriage.
If this does not work for your printer it may have a button or menu option to move the carriage over. You should be able to find a down loadable manual at the printers manufacturer website.
E.G. Lexmark.com
Hope this helps, if not please ask further.
Jei
Dec 14, 2008 | Lexmark Z1300 InkJet Photo Printer
New cartridge 70 black will not print
buy some new one..... i think thats old one hahahaha joking ....fix the cartrige
Mar 01, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Head probs
How long u have the cartrige?
If it is a new cartrage make sure you remove the plastic that cover the printing head. (at the bottom)
Tell us more... info
Thanks
Jaywizz
Nov 19, 2007 | HP PSC 1210 All-In-One InkJet Printer
22 people viewed this question
k24674
jasbo
jasbo
