Question about Tablets & eReaders
How do I manually reset my Trio g1 7" when I can not get to the setting to click the "factory reset"
Factory reset trio g5
You are talking about a generic Android software reset?
Google gives instructions here: https://support.google.com/android/answer/6088915?hl=en
Factory reset your Android device
  1. Open your device's Settings app .
  2. Under "Personal," tap Backup & reset. If needed, enter your PIN, pattern, or password.
  3. Tap Factory data reset Reset phone or Reset tablet. If needed, enter your PIN, pattern, or password.
  4. To erase all data from your device's internal storage, tap Erase everything.
  5. When your device has finished erasing, pick the option to restart.
  6. Set up your device and restore your backed-up data.
If you can't open your device's Settings app, you can try factory resetting your Android device using its power and volume buttons. We recommend seeing your manufacturer's support site for device-specific instructions.
Aug 23, 2017 | Tablets & eReaders
How do you get the reset to factory to get it starting back
Hi most tablets r similar look for settings or tools icon click it on it should open wireless & network page or similar scroll down to back up & reset click on & follow instructions good luck
Mar 06, 2016 | Mach Speed Trio Stealth G2 8 inch Tablet...
How do I do a factory reset?
Hi There.
Under Settings, there should be a scetion called "Backup and Reset" - The Factory Reset option will be in there.
Hope this helps!
Jan 14, 2016 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How do i get my axs trio tablet out of demo mode and user terminated?
It happened to me also after I clicked on Trio Watchdog just to see what it does. Immediately I stopped the app and "removed" it, but although it disappeared from the App list obviously it was still hidden somewhere. Could not use SETTINGS to see it running and stop it because SETTINGS will not stay up also, same ....demo message.
The solution, for me, was to open the factory loaded App Permissions app and go to the startup section where I unchecked Trio Watchdog. I than rebooted the Trio AXS tablet and was back to normal.
May 24, 2015 | Tablets & eReaders
My trio stealth is new. When I power it on, goes to a screen "@9dual core" and doesn't go any further. Help!
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also work, I've learned, on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned. But.... TRY AT YOUR OWN RISK. Here it is.
(1) PRESS AND HOLD the power button until the tablet shuts off completely.
(NOTE:
if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.)
(2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button
This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic.
(3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices.
(4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings).
(5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step.
This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items.
Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok?
Happy New Year, 2015 ... & ....Good Luck!
Dec 28, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
How i unlock my tablet?
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also I've learned work on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned as well. But.... TRY AT YOUR OWN RISK. Here it is.
(NOTE:
Dec 23, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
I have a trio stealth g2 10" and it was stuck on the start up (logo) page. I tried the hard reset (holding -volume and power button) and it worked for a day then froze up again. When I tried another h
I cases like this you might not have a choice but to factory reset to fix the start-up error. Repeat a hard reset (Vol up/Power button) and make an effort to get to the tablet Settings after boot up. Get to the Settings>Backup & reset>Factory data reset. In the majority of cases a factory reset will resolve critical issues. This is thought of as a "nuclear option."
If this nuclear option fails then a more complicated process that's beyond this post is to consider installing a custom Android ROM after rooting the device. XDA has a forum discussing rooting and installing custom ROMs for Stealth tablets: http://forum.xda-developers.com/showpost.php?p=34126848
Good luck.
Nov 20, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
My trio stealth 8 keeps resetting it self to defult setting what can i do to fix
Try doing a factory reset. It can be done from the setting menu usually, or via a special button combination. Google will help you if you google your model number and 'factory reset'
Sep 16, 2014 | Tablets & eReaders
Tablets & eReaders Logo
80 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
