Question about Pool & Spa
I came home I did not hear the pump working so I pushed the button to turn on the jets and they seem to work fine, but when I shut the jets off everything shuts down. Just humming coming from motor.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
That is a capacitor. Replace it. If it blows another or hums like that, then get a new motor. Also, see if the motor shaft turns freely.
Posted on Jan 21, 2017
New homeowner. Kohler airjet Master tub after hitting power button only stays on for about 20 seconds. Home inspection working fine I believe
put your ear to the side of the tub and momentarily turn on the jet pump, if you hear a humming sound then you need to replace the pump motor capacitor.
Jan 07, 2016 | Home
Have an Emerson model # R63MWENA-4727 on my Hot Tub. Runs continuesly fine. But when I turn the jets on I hear a " click" and it won't run.
It is a problem in the relay of that one motor in your spa electronic control most likely. If you have many jets buttons, you can unplug 1 pump from the control and plug in another relay see if the motor works.. if it doesnt work it your motor if it does work then its the relay in the controle system.
Sep 04, 2015 | Emerson Pool & Spa
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
Jets won't stay running
Sound like a bad switch. The contacts are likely corroded or broken.
Aug 23, 2017 | Jacuzzi NOVA 5 WHIRLPOOL WITH INTEGRAL...
Pump starts spontaneously without pushing the switch button
This sounds as if a relay has gone out on the circuit board. There really could be no other reason for the pump to come on without pushing the button.
You will need the model number of the control box so you can find a replacement.
Rod
US Parts Center
Jan 18, 2013 | Maax Home
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
Pushed button to turn on whirlpool - hear motor - jets don't work
if the motor just hummed then it is likely a bad motor. you will need to replace the pump at that point. Bathtub buttons like the one you have either works or they do not. there isn't any in between areas.
May 31, 2010 | American Standard Cadet Corner Bathtub -...
Seems to be no pressure . water spray jets noy
sometimes if dishes aren't rinsed well food gets caught in the pump intake reducing flow,try clearing intake of pump
Jan 31, 2010 | Dishwashers
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
Washer fluid pump not humming or trying to push fluid to windshie
disconnect the connector and have a friend push the washer button while you check the wires for power with a test light.its probably a bad motor, they are about $15.00
Dec 22, 2009 | 2002 Toyota Highlander
Pool & Spa Logo
568 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
