Question about Garden
Manual for ariens path pro 208cc electric snow blower
  • 43 Answers
SOURCE: one side of my ARIENS ST928 SNOW BLOWER doesn't work
most likely you have a broken shear pin. Look on the side that works, there should be a bolt or pin through it. The side that is not working is probably broke off. Find the hole in the auger and line it up with the inner shaft and replace with proper shear pin/bolt. Shear bolts can be obtained from most outdoor power equipment shops. I do not suggest replacing with standard bolt as it can cause damage to you gear box it auger gets jammed.
Posted on Dec 19, 2008
  • 43 Answers
SOURCE: owners manual
Here is a link to find all manuals
ariens manuals
Posted on Dec 21, 2008
  • 19 Answers
what would you want that for? a blower is a blower, change the oil twice a season and brease every nipple you see. lol
Posted on Nov 26, 2009
  • 6 Answers
SOURCE: Snowblower seems weak for a 5HP
Check to see if there any surface rust inside the auger assembly. This will cause this problem. Also, you try a silicone spray on a painted surface.
Posted on Jan 06, 2010
  • 171 Answers
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Posted on Jan 10, 2011
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
Snowblower won't throw slush
Most snow blowers will not blow slush or wet snow as it packs and plugs itself up. This is normal.
Do not unplug with the blower with it running as you could lose your hand in the process.
Jan 24, 2015 | Power Smart Red, Black Db765126 Db7651...
Starting poulan pro snowblower
gas spark and air , if you have these 3 it will start , which one do you not have
Jan 12, 2014 | Poulan Pro Pr621 21-Inch 208cc LCT Gas...
Ariens 30 deluxe platinum series won't start
Is this your first attempt of the season to run it? Did you totally drain and run the machine out of gas last year?
10% Ethanol gas left in a carburetor for months is a killer
Jan 03, 2014 | Ariens Snow Blower 921013 ST30LE 305cc 30"...
How to take a carburetor off an MTD Snow Thrower
Get user manuals for craftsman snowblowers to train yourself in clearing the pathways that are fully covered with snow.
Dec 15, 2013 | Mtd Yard-Man 26" 208cc Two Stage Gas...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
