Question about Verbatim Computers & Internet
My Verbatim external harddrive is dead is there a way to get the information off it.
    Problem Solver:
  • 10 Answers
Http://www.drivesaversdatarecovery.com/
How can I retrieve my information from my verbatim hard drive 320gb? It isn't opening.
Take the drive out the caddy and plug it into a computer using a SATA to USB cable. If the drive doesn't spin up then it's a dead drive and you'll need to use a data recovery company
Jul 17, 2016 | Verbatim InSight 320GB USB 2.0 2.5...
Wrong adaptor plugged into hard drive
you can use a external hard disc connector ,,, but still you must open the box ,, i think the guarantee is already void ,,, cause misuse is not guaranteed any way you must ask about the guarantee thing ,,,
Mar 06, 2012 | Computers & Internet
Verbatim hard drive
Hard drives are fragile, and if they fall sometimes you get lucky and other times no. The only solution is to bring it to a computer store in hopes they can extract your files.
Mar 05, 2012 | Verbatim External, USB 2.0, 500GB...
My daughter just dpopped my hard drive on the floor and now it's not recognised on my pc....any help!!?? It's a verbatim 640 GB
The Verbatim external harddrive may be damaged beyond warranting repairing, either from you, or a professional computer shop.
Allow me to explain the construction of an external Harddrive, plus the Harddrive located inside the case, and what may have resulted from the fall.
Basic construction of an external Harddrive, (IDE or SATA)
1) Plastic external case. Also referred to as an External Enclosure. Usually comes apart in two halves.
2) Small circuit board located inside, with an interface that the Harddrive plugs into.
3) Harddrive. IDE or SATA. Can be a 2.5 laptop harddrive, or a 3.5 desktop harddrive that is used.
[A laptop harddrive is 2-1/2 inches across in width. A desktop harddrive 3-1/2 inches.
If you have the Verbatim Leather Wallet 640 External HarDDrive it has a 2.5 inch laptop harddrive inside. The harddrive is a SATA unit.
http://en.wikipedia.org/wiki/SATA
View of an average 2.5 inch (Laptop) 640GigaByte harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5260951&CatId=2681
(The harddrive inside the Verbatim external harddrive enclosure, may not have a clear see-through cover to observe the internal workings )
The back end of the harddrive has contact pins. These pins line up with an interface.
The interface is a block with matching socket holes for the contact pins.
(Or more than one interface may be used)
The interface 'block' may be attached directly to the circuit board, that is inside the Verbatim external enclosure (Case), or may be attached to cables (Wires) that are then attached to the circuit board.
A) Point; The circuit board may have a crack. (Copper circuit trace is torn, or more than one)
[Circuit Board. Also known as PCB. Printed Circuit Board. Crude description of construction is a laminated board with very thin copper wires on it.
This information details out the construction of PCB's,
http://en.wikipedia.org/wiki/Printed_circuit_board ]
If cracked the circuit board MAY be repaired. Finding the open circuit, (Broken circuit trace. 'Copper wire'), may be VERY tough.
The circuit board may be replaced. From the factory will cost $$$$, and perhaps the loss of information that is on the harddrive.
To my knowledge the needed circuit board is not sold to the average consumer. This would mean obtaining another like Verbatim 640GB external harddrive, and using it's circuit board.
Not feasible.
More feasible; The harddrive would be removed, an inexpensive external enclosure procured, the harddrive then installed inside, then the USB cable from the external enclosure is attached to a working computer, and personal information is then copied off.
(Hope you're not an English teacher, and reading the above, lol!)
B) Basic construction of a Harddrive:
1) Inside the hollow empty metal shell of the Harddrive are two motors.
The Spindle motor, and the Actuator motor.
There are 3 to 6 Platters inside the Harddrive. (Perhaps more in today's Harddrive's)
The Platters resemble CD or DVD disks, and are usually composed of metal or glass.
The Spindle motor drives the Platters.
EACH Platter has a magnetic media applied to it's top surface, and bottom surface.
The magnetic media is arranged in a pattern of 0's and 1's.
1 being ON, 0 being OFF.
(The magnetic media is arranged in Sectors and Tracks much like a CD or DVD disk)
The Read/Write Head arranges the magnetic media. The Write portion of the Read/Write Head does this. (The Read portion does as it implies. It reads the information on the Platter)
There is a Read/Write Head on the Top, and on the bottom surface for EVERY Platter.
When the computer is off the Read/Write Head is in a parked position, and away from the Platter.
When the computer is on, the Read/Write Head is 'hovering' right above the surface of the Platter.
The distance of the Read/Write Head to the surface of the Platter is VERY CLOSE.
The Read/Write Head is attached to an Actuator Arm. This arm swings the Read/Write Head back, and forth across the surface of the Platter.
(When operating, the Actuator Arm can swing the Read/Write Head back, and forth across the Platter at Hundreds of Times a Second!)
Point; If the Verbatim 640GB was plugged into your computer with the computer on, and then dropped, one or more Read/Write Heads could have crashed into a Platter. (Or Platters)
This would result in wiping off some of the magnetic media, and may have rendered the Harddrive useless.
I know. I'm just a ray of sunshine.
I would suggest removing the harddrive out of the Verbatim's case, and installing it into a matching external enclosure, to try to remove any needed data.
OR take it to a professional service that recovers information from damaged harddrives.
An external enclosure is cheap,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2781
This is to just check out the harddrive, and see if it's still functional.
For questions, or clarification to what I have stated please post in a Comment.
Regards,
joecoolvette
Apr 24, 2011 | Verbatim Computers & Internet
Hello, i have a VERBATIM hard drive USB 2.0 it cost me a lot of money :-( i've hardly used it! it has been handled in cotton wool tonight, when transferring data to it from my computer it has...
1. First power down the computer and the external hard drive.
2. Disconnect the drive.
3. Wait a minute.
4. Start your computer.
5. Connect the Verbatim drive again.
6. Wait a minute. (While waiting, check the screen for popup messages telling you the harddrive is ready and received a drive letter.)
7. Check "My Computer" for the harddrive.
8a. If you see it there, click it and make a copy of the data you have stored on the drive immediately!
8b. If the drive does not show up, you probably have a problem that will take deeper looking-into.
A clicking sound from a harddrive is never a good sign. While it does not mean immanent ***** of the drive, getting the data from it is now a matter of luck. In any case you should not trust the drive and should replace it as soon as possible.
Jul 01, 2017 | Verbatim SmartDisk Firelite Portable USB...
How do I copy my complete music files from my computer windows 7 to Verbatim external hard drive with Nero software?
Hi!
Unless I'm misunderstanding, you shouldn't need to use Nero at all to copy your files.
If you use Windows Explorer and locate the directory with your music files, you should be able to just do a copy and paste to a directory on your external harddrive.
Mar 26, 2011 | Computers & Internet
Hello, my external harddrive (Verbatim, 500GB USB/FW800) stopped working. When connected the blue LED lights up. After 3 sec it goes into flash mode. The HHD makes a clicking sound. The MAC Hard disc...
> the HDD makes a clicking sound.
That's a very bad sign. :-(
> find a way to rescue the [files]
Search online for a professional "data recovery service". For a significant fee,
they can repair your disk-drive, just long-enough to copy your files onto a brand-new disk-drive.
Nov 03, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Computers & Internet Logo
93 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
