Question about Electrical Supplies
Replace lightolier e600 with standard 3 way switch. ER-3 switch by lightlier is on other side of the room.
Replaced e600 with standard 3 way switch (using led lights-old e600 did not like led lights. flickered or shut off). ER 3 switch on other side of room only has a black and white wire. standard 3 way switch replacing e600 works. 3 way replacing er3 does not work.
  • 21 Answers
SOURCE: told motor was bad, replaced motor, new motor does not run
Black to Black, Purple to White and the new motor requires a run capacitor which brown goes to one side of capacitor and brown/white goes to the othe side of the capacitor. This is providing the old motor is a single speed. If the old motor is a two speed you have an incorrect replacement motor.
Posted on May 02, 2009
  • 704 Answers
SOURCE: I am replacing a combination 2 switch using a
First, turn off the power to this circuit to avoid getting a shock.
If the two devices that are controlled by the combination switch are lights, you will want to join the two (2) white (neutral) wires together with a wire nut, as these are not connected to the switch.
You also want to connect the bare copper wires (ground) together and connect one of them to the switch's green grounding screw and IF the wall box is metal, you also need to attach the ground wire to the box with a green grounding screw.
Now, you can connect the wires that go to your lights, the red and black wires that are part of the same wire and are routed to the same location thru the wall box. Take either the black or red and connect them to the screws on the side of switch that are not connected together with the small brass strip between them. Put the red on one of these screws and the black on the other.
Now with the black wire that is the hot (Common), this is the one that is bringing power into the wall box, should be connected to the other side of the switch, the one with the two (2) screws that are joined together with the brass strip between them.
This will allow you to turn on and off each of the lights (or a fan, etc) separately with each switch sharing the common power source.
Here's a picture of the switch that shows the side of the switch with the common side and the brass strip that connects the screws together. This is the side where the one black (hot / common) wire that supplies the power gets connected.
You can also open up the box the switch came in and you'll find a wiring diagram for the switch that illustrates how to properly wire the switch for your application.
I hope you find this Very Helpful and best regards!
Posted on Oct 10, 2009
SOURCE: GE Timer #15086 has
GE 15086 programmable timer replaces single-pole switch only.
Single pole means 1 device turns Load on-off.
3-way is where 2 devices turn Load on-off, for example 2 switches located in hallway.
Your existing timer has white, black and blue wires.
Your new timer has white, black, red and green wires.
Green wire connects to bare ground wire in every occasion with every wiring device.
Electricians don't guess, they test the other wires.
Remove old timer.
Separate wires for testing.
Turn on power.
Tape ordinary tester leads to wood sticks to keep hands away from power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. The Hot wire will connect to timer black wire.
Now test Hot wire to each other wire (except bare ground)
Tester will light up on Neutral wire. Neutral wire connects to timer white wire.
The remaining wire connects to timer red wire.
After connecting timer, push manual override button to check that Load turns on-off.
Manual override on 15086 is the door that covers buttons > use door as push button to check Load.
Next, program the timer.
Programming is straightforward and similar to other timers.
If you have a problem, add a comment.
You can also take advantage of Fixya phone support. Expert will walk you through the steps for a price.
Posted on Dec 22, 2010
SOURCE: I bought a Leviton 1201-PLC 15 Amp, 120 Volt,
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 09, 2011
  • 3289 Answers
SOURCE: Installing a Lightolier 600VA general inductive dimmer switch.
Hi James, I'm an electrician and can help you with this problem.
From what you describe, the wiring in the switch box is for a standard, single pole switch or dimmer, and is not compatible with this replacement switch. Here's why: you stated that there are (2) wires in the box, a black and white insulated wire, that once fed a dimmer switch. Common wiring practices would suggest to most electricians that the white wire is the 120 volt "hot" supply and the black is the switched leg - or output of the switch to the fixture.
The replacement inductive dimmer switch is not a standard switch. It is designed to control inductive loads - or motors such as a fan. It does not simply control the flow of current - but actually uses a small amount of electricity to do this. This means it needs a complete 120 volt circuit consisting of a neutral and hot wire; and wire for the output of the switch to the motor. A total of insulated 3 wires. You have only two.
If you have a neutral in the box, you can use the switch if wire like this:
120 volt "hot" to the switch Black
120 volt "neutral" to the switch White
120 volt load wire (to motor) to the switch Red
The switch Yellow should be taped or capped off and is used only in a three way application.
The "arm switch" cuts power and the wheel is used to set low speed setting. You can see the info sheet here.
As mentioned above, this switch is used to control a motor - not a light. The same way a dimmer is used to control a light - not a motor. If you do not have access to a neutral in the box, you should either install one or, use a different switch. There are motor speed control switches that do not require a neutral wire and cost under $25.
If you need to control both light and fan there are products that are installed in the canopy of a paddle fan that will do this for under $50 and are operated via a wireless remote that can be secured to the wall such as those below:
These can be found at Home Depot, Lowes, and electrical supply stores.
I hope this was helpful & good luck!
Posted on Apr 20, 2012
12v Spotlights flicker
Conversion from halogen to LED lighting is not a simple plug-and-play process. The power supply is delivering more than 12v because the LEDs draw less current. The flicker could be evidence that the LEDs are gradually breaking down.
Dec 09, 2016 | Kitchen Ranges
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Testing nuetral lamp
Hi David
Use a Multimeter & check for continuity in filament.
Your vehicle has a 12v Battery? Right?
Connect bulb across 12v battery using jumper wires to either side of bulb. (Out of Circuit)
Otherwise the Neutral switch is out of position or damaged.
Bulb in circuit will probably have 12v on one side and the Neutral Switch provides the ground to make it light.
If it is a bulb that is blown... I would replace it with an LED.
You can even make your own LED replacement with a simple standard LED from the local electronics parts store, any colour. Just be sure to add a 560 to 1K ohm resistor in series to limit the current from the 12volt circuit.
Then it will never blow again.
LED 5mm White Waterclear 18000mcd Standard LEDs Optoelectronics Active...
1K Ohm Carbon Resistors 1 4W 5 Pack of 5
Jan 03, 2016 | ATVs
LED Lighting
Not really no. There are kits available but all to often there are laws and standards for vehicles in which the conversions do not abide by. Make sure you research what is legal before attempting such, usually is not worth it.
Dec 08, 2014 | 2004 Lincoln Navigator
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
I installed 2 3 way lighted dimmer switches (DR703PWV) in my Living room Chandelier, and the control for On & Off is working as it is supposed to, but when I try to dim the chandelier flickers from...
Install one dimmer at the load end feeding the light. Install a standard 3way switch at the other end. Make sure the dimmer switch is rated for the type of bulbs in the fixture. ie Led, halogen etc.
Mar 16, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Hampton bay CFL lights flicker when they are turned off
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Apr 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Electrical Supplies Logo
154 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
