Connect to vga - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 26,222 Answers
Connect what to VGA.
Posted on Dec 28, 2016
I am receiving a CABLE NOT CONNECTED error when I connect my vga monitor to my laptop using an VGA to HDMI cable
If you actually have a cable with HDMI on one end and VGA on the other, it will probably not work. HDMI uses a digital signal and VGA uses an Analog signal, there needs to be some circuitry somewhere that handles the conversion. You are probably getting Cable Not Connected because the monitor is scanning for an Analog signal and not recognising the digital signal coming in over the VGA port.
Get a HDMI to VGA converter
Jan 22, 2017 | Vga Computers & Internet
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Conecting computer to view screen
Hello
Your JVC Tv has AV & Component video inputs only. No direct connection facillty with computer is there. Computers outputs VGA stream video. VGA stands for Vodeo Graphics Arrey. This video stream cannot be connected directly to your JVC set. There are sets, which have this facility, but your set have not.
If you want to connect this set to computer, you have to buy one converter [VGA to RCA out], from open electronic sparepart selleing shops at your town. It will not cost more.
If you have this converter, you can connect your computer directly to the VGA converter, using a VGA to VGA cable, and the output from the converter by RCA connecting wire to TV. In short, the converter will be in between TV and Computer.
VGA to Video converter will look somewhat like this. OK.
Dec 14, 2011 | JVC AV-32D305 32" TV
Can i hook my lap top up to this tv to get netflix? How?
Hello
This model CRT tv cannot be connected directly to lap top. Laptop has VGA output and there is no VGA input to this TV. Tv has only AV sockets to connect in. You must have a VGA to Audio Video converter to be used in between TV and Laptop. This device can be bought from electronc shops. It will have a VGA input, and audio video output. You have to connect your laptop to this device using a VGA to VGA connecter, and from this devices' output, you will get audio video output, which can be connected to TV and select the TVs' input to AV. OK.
Jun 03, 2011 | JVC AV-27F702 27" TV
What type of cable do I need to connect my macBook Pro to a Dell DLP MP1200?
You should be able to use a USB - 4 pin mini-DIN cable with this projector.
Mar 01, 2011 | Computers & Internet
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
How to get laptop connected with vga connector to
Unplug the television. Connect the VGA compatible monitor cable from the laptop's VGA monitor Output to the VGA Input on the back panel of the television. You will need a splitter to connect the audio cable from your laptop to the VGA Audio Input on the television. Never mind if you have speakers connected to your computer.
Press the Device button on the remote control or on the television front panel to display the Device Selection Menu. Select the device you want to view, in this case VGA. The only compatible resolution is 640X480 at a sync rate of 60 Hz.
Do not leave stationary or letter-box images on-screen for extended period of time to avoid uneven picture tube aging.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
