Question about Frigidaire Dryers
My frigidaire dryer is giving me an EF1 code after about 2 minutes of operation . Can't find any solutions referenceing EF1
2 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: error code E9E
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This is an electronic problem and must be replaced by factory service!
If it happened from th beginning call factory service right away, it's under warranty, you do not pay for it!!!!!!!!
There is no other choice!
If the dryer was 10 years old I would recommend to trow it out and not spend a dime on it! Are you ready to buy a new machine??
If not let service fix it and get back to having clean clothes!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
EF 2 code frigidaire dryer
Only Codes listed that are close on Tech Sheet are EF1, EF3 and EF8. Many Other codes but not in that format. There is an EF2 Code for Frigidaire washers for oversudsing.
Nov 18, 2015 | Frigidaire Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LW0) has an "E64" message listed. What error is this in reference too?
Good Morning Yasmin Abdullah, I am happy to assist you!
Based off the information you have provided your Frigidaire dryer is displaying error code "E64". "E63" typically stands for heater open circuit, which means that it could be a faulty wiring harness or heater. I would suggest performing a reset on your dryer by disconnecting power from it for ten minutes. This could be a false error code or a miscommunication within the board and a reset will help to clear that out. I hope this information is helpful to some degree. -Matt
Dec 16, 2014 | Frigidaire Dryers
Want to find fault codes for volvo s40
Hi there:
Both fult codes are refer at Ignition System or Misfire.
DTC P0311 - Cylinder 11 Misfire Detected
DTC P0323 - Ignition/Distributor Engine Speed Input Circuit Intermittent
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 16, 2012 | Volvo Cars & Trucks
Brand new Frigidaire Electric Dryer gives Error E61. Store brought out another identical dryer with same result. Help please!
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Note: You may need the service of a certified electrician for this task.
Jul 13, 2011 | Frigidaire Electric Dryer
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Mar 23, 2009 | Frigidaire Electric Dryer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
152 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
