Question about GPS
My tom tom says no maps found. how do I restore the maps and other info?
Fully charged will not turn on or reset unit is not damaged had been working fine. turned it off and now nothing.GO 2535 WTE
Restoring your Favorites and personal settingsIf you reset factory settings or update your map you can restore your favorites from a device Backup.Your Favorites are located inside your map folder, stored in the file MapSettings.cfg. This file consists of the following:Home addressRecent destinations Favorites Connect your Tom tom to the computer and select the option below that best fits your situation:If you are going to be installing a new map to your TomTom or you plan to perform a factory (hard) reset on your device, choose Backup and restore Favorites from your TomTom. If you have already installed a new map or performed a factory (hard) reset, choose Restore your Favorites from a previous backup.Restoring Favorites from a previous backup can only be done if you have previously performed a backup of your Tom Tom device.
Aug 18, 2011 | Tomtom GPS
Tomtom xl says no maps available after installing new update from tomtom home
when your registered it with tom tom they take note of your maps
check your online tom tom account and it should let you re-download your maps.
I you backed it up to your computer you can also restore the maps from there with the tomtom home software
Aug 22, 2009 | Tomtom One XL GPS Receiver
I have a tom tom go 700 which i used only occasionally for the last 4 years England & spain.last weekend i downlouded speed camera data into it except for relative speed information. i turned my sat nav...
after speaking to another owner of a simulal tomtom go 700 iwas told to pres the restore button at the rear of my unit and that solved that problem. kledwood
Apr 08, 2009 | Tomtom GO 700 GPS Receiver
Brand new Tom Tom One 125 showing blinking red X when turned on
I was able to speak with Tech Support at Tom Tom and got sent some links for solutions to these problems.  I was able to solve the problem following directions from this website.  Without that response of the support person to this specific problem, I would still be without my new GPS system.  Turned out that there is a conflict with the MAC OS and updates to Tom Tom, but there is a solution to this that worked for me.
If you get the continual red circle with blinking "X" and recently tried updating either your maps or most recent app, here are the two web links that will solve the problem:
www.tomtom.com/10324 (to disable SPOTLIGHT from causing a conflict on the Tom Tom ONE)
www.tomtom.com/9091 (general info for removing software and re-installing software to the Tom Tom ONE)
Do the disabling of SPOTLIGHT first, then remove and re-load software for Tom Tom ONE.  Good Luck.  This did the trick for me.
Jan 25, 2009 | Tomtom ONE GPS Receiver
Mistakenly formatted sd map
woops , where are you ? ( in the world ) and contact info ?
Nov 14, 2008 | Tomtom GO 300 GPS Receiver
No maps found??
my tom tom 510 would start, i have charge the tomtom with green light on, but tomtom is not coming up
Feb 09, 2008 | Tomtom GO 510 GPS Receiver
Tomtom one
Hi Steve de may.
Try removing your SD card and inserting again. If the problem persists then I recommend you use your backed up copy to restore the SD card. You did make a back up on your PC, right?
The other possibility is that in the preferences section of you tom tom the wrong map has been selected or a map that it cannot read has been loaded. Remember newly purchased maps must be activated first before use.
I made a copy of may original SD card and use that in my tomtom. If anything goes wrong, I can always restore it from the original. I also made a copy on my PC using the Tomtom "Home" application.
Hope this helps.
Regards,
Spare head 2.
Jan 03, 2008 | Tomtom ONE GPS Receiver
Tom tom 910 map no found bloplem
i knew tomtom 910 the best gps . so that why i buy it , but some time has bloplem i need help . if any want gps i recomender that buy the tom tom 910 is work for that money cause i got 1 year and now i bether and knew many new location .
Jun 19, 2007 | Tomtom GO 910 GPS Receiver
GPS Logo
26 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
