Question about Amazon Fire TV Stick
Firestick replacement remote
Where can i get a remote for my firestick
How do I get an amazon fire stick to work on my Panasonic plasma tv model TH-37PX70BA
  1. Plug your Firestick into one of the HDMI ports on your TV. Plug the USB power cable into your Firestick and into the wall or a USB outlet on your TV (if there is one)
  2. Turn on your TV and set the INPUT device to the correct HDMI port. There should be a splash screen or setup screen on your TV at that point.
  3. Using your Firestick remote, navigate to network settings and scan for your WI-FI router, Then enter the Wi-Fi password for your router (the same one you use for your smart phone or laptop).
You should be able to fully use your Amazon Firestick, and if you have Amazon Prime, be able to access all prime and free offerings from Amazon.
Dec 28, 2017 | Panasonic Computers & Internet
Ireset my fire stick to factory and now won't work
hi there.
this is all i can find out.
How do I fix my Firestick? Hold down the Select + Play buttons together for 5 seconds to Restart the device. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. problem with the Amazon Fire Stick and the remote.30 Sep 2015
SOLVED: Why won't my Amazon Fire TV remote work ... - iFixit Search for: How do I fix my Firestick?
or try this link for more help if you need it.
amazon fire stick not turning on Google Search
Nov 26, 2017 | Computers & Internet
How do i get the firestick on my tv screen..set on hdm1 or hdm2 or ? I don't know how to bring it up on the screen?
The TV remote has a button for that. Input Select or Source or SEL. However simply turning off anything except the firestick should make it work. I presume the firestick came with a remote. Simply turning it off and on from that should do it. Make sure you can see the firestick when you press the buttons.
Oct 21, 2017 | Televison & Video
Trying to get closed caption on my firestick. Directions say run movie then press menue nothing happens! Where is menue on firestick?
To activate your closed captions, start by clicking the center button on your Amazon remote to launch your player controls bar.
Simply click on the CC icon to activate or deactivate closed captions.
Sep 11, 2017 | Televison & Video
I installed my Fire Stick yesterday when I try to use Alexa it says it can not condect. What do I do ?
Make sure the Firestick is connected to your network correctly
Make sure the Remote is paired to the firestick
Mar 02, 2017 | Televison & Video
My firestick remote will not work
1.Replace batteries.(in remote)
2.Get within 12 inches from firestick.
3.Press and hold home button for 10 seconds.
This should now pair with firestick, and should work
Feb 21, 2017 | Televison & Video
How do I get live tv with my fire stick
I have no experience of these but as they work by connecting to the internet nothing is live in the conventional sense but streamed either from a single or a series of websites the firestick is programmed to log on to. The website(s) will usually provide a mixture of "live" tv, catch up tv available for a limited time, archive material and special programming and some movies.
What you get will depend on what is available free and what needs to be paid for, your internet/wireless connection and how good you are at reading instructions and operating the remote, assuming the firestick is working correctly.
A friend had a problem with connected tv and it turned out some of the sites took a long, long time to load and he was impatient and assumed it wasn't working.
Jan 10, 2017 | Televison & Video
My firestick remote wont work
This should now pair with firestick, and should work.
Jan 07, 2017 | Amazon Fire TV Stick
Why did it suddenly stop working?
the "pat answer" is the magic smoke leaked out. all electronics work on magic smoke, once it gets out of a device, the device wont work anymore. OK smoke comes from burned out devices. Point the remote at a digital camera and watch through the view finder, does the led in the remote light up? (you cant see it with the human eye) if so next step. plug the dongle into the TV, select the correct input and point the remote directly at the window on the dongle and try to operate the fire stick, if it works, you may need an HDMI EXTENSION cable (male to female) to move the dongle to a position where it isn't blocked from the view of the remote. Also, can you operate it from your computer using Google Chrome and the correct firestick extension? (incase the remote isn't infrared operated)
Apr 03, 2016 | Amazon Fire TV Stick
Amazon Fire TV Stick Logo
57 people viewed this question
Top Amazon Televison & Video Experts
john cordey
john cordey
Thomas Stauber
Thomas Stauber
Ron Harvey
Ron Harvey
Level 1 Expert
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
