Question about Sewing Machines
Thread cutter on my ellure wont cut - Sewing Machines
Michaelle
  • 65 Answers
SOURCE: thread problem
I'm not sure which thread you are referring to, its either the bobbin thread (under) or the needle thread (above.top)
I'm sure you can find some helpful advise here on the baby lock site
http://www.babylock.com/support/faq/?FAQ=10
Posted on Jan 25, 2009
  • 371 Answers
SOURCE: Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Posted on Sep 26, 2009
  • 201 Answers
SOURCE: The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Posted on Apr 09, 2010
  • 1788 Answers
SOURCE: pfaff quilt expression 4 It shreds
Are you using the right needles, size and type? Before, you wreck your material, take it in and have it serviced. I know everyone hates to pay for service, but if you like your machine it will be worth it to have it running at its peak. Just like a car, we spend tons on them but expect a sewing machine to never need anything. Remember, it is worth it.
Posted on Sep 13, 2010
SOURCE: we are hving problems with
hi there
1 - remove throat plat and mak sure the movment for thread cutter working or NO if working maybe need to change fixed knife or movable knife.
2 - if no movment mak sure plug for cutter solenoid is connect secur.
3 - make sure the output signal is coming to the cutter solenoid or no.
4 - maybe solenoid is dameged and need to change.
with my best regards
ashraf abozid
aabozid@hotmail.com
Posted on Dec 03, 2010
How do I fix automatic thread cutter on the brother PC 420?
I am not sure what to do about it. Did you try clean the shuttle real well? If that does not work, call Brother!
Oct 13, 2014 | Brother PC-420
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
Why the bobbin wont wind correctly
My Brother has another spindle to wind the bobbin. Be sure to thread the thread through the two loops. I wind the thread around the bobbin a little and then start the machine. I find that using the cutter on the bobbin spindle helps to hold the thread on place.
Jul 06, 2014 | Baby Lock Ellure
Automatic thread cutter.bobbin thread does not feed to the top.
when you stop sewing where is the arm located ,up or down ..that will make a world of difference
Jan 06, 2014 | Elna 7200 Computerized Sewing Machine
When using the cutting thread button on the brother pe770, it's pulling the shirt down and wont release
the machine may need to be checked to see if there is something
wrong with the connection between the button & the cutter
Sep 13, 2012 | Brother PE770 Computerized Sewing Machine
Thread cutter not working
you might consider having the machine serviced to find out why the thread cutter isn't working
Apr 30, 2012 | Juki TL-98Q
Friday I purchased a new Baby Lock Ellure Plus from a dealer and have had nothing but problems since. It worked fine in the store. The problem I'm having is with the automatic thread cutter not
when you take it back, write down your questions on paper & make sure they show you that everything works before you take it home, that machine should run like a charm,,
Jan 28, 2012 | Baby Lock Ellure
Feb 28, 2010 | Husqvarna Designer I
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
