WM2688HWM is leaking after the finishing the wash cycle at the right bottom.
I ran the washer with the top cover removed and couldn't detect any leaks during the wash cycle or shortly after. Than after a while a small puddle was showing up underneath the filter and pump area left front corner). But I couldn't determine where the water is coming from.
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
SOURCE: Water leaks during rinse cycle
My Washing machine is leaking in gearbox.the quality of water is bad (Hard)
Posted on Aug 07, 2008
  • 734 Answers
SOURCE: Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE: Washer leaking water from bottom
MIne did and it was the bleach container on the top that was getting clogged and leaking over, we actually drilled the hole a bit bigger and cleaned it all out and it stopped. I've had to take the whole top of the washer off to do this about 2-3 times now.
Posted on Dec 26, 2008
  • 25 Answers
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check
Yours Truly,
Posted on Aug 12, 2009
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
It seems to be flooding at the fill part of the cycle.. water level seems right but there is water coming out near the base at the back... The issue was first noticed after a finished cycle still was full...
It usually is, but you'll need to first determine where it's leaking from. You'll need to run it with the back off to find the leak. An exploded view should be available at
Feb 14, 2011 | Hoover HTC243 Top Load Washer
Washer leaks out of the bottom. checked drain hose it is not plugged, checked hot and cold water hoses they're ok.
Oct 25, 2009 | LG WM2688HWM TROMM SteamWasher
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Leaks during wash cycle. need to get cover off without destroying the washing machine. looks like new now!
at the bottom of the front panel are 2 screws you need to remove ( easier to tip machine back a little to get to screws. then pull the bottom of the panel toward you. as it swings out, the top of the front panel will release. you should be able to find your leak from there. shane
Aug 25, 2009 | Maytag LAT3600A Top Load Washer
Amana NAV5800 - How do I take off the lid/cover
There should be two screws at the bottom of the front panel. Undo these screws and the bottom of the panel should swing out. The top will be held by clips or pins that will release as the bottom of the panel moves out. I suggest you lay a folded towel on the floor to prevent chipping the enamel finish when the panel drops free.
By the way, please ensure the machine is unplugged before you attempt any work on electric appliances.
Good luck
Bob Thompson (Australia)
Dec 22, 2007 | Amana NAV5800A Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
