Question about Samsung Televison & Video
Samsung plasma 55" tv won't power on. Model: 850FH-YB01. Bight flash on wall behind the tv. TV off. I think my power source is bad. But what is that, How or where do I purchase one from?
  • Samsung Master
  • 2,189 Answers
The power board is the one that the power lead connects to on the back of the panel there is two fuses on the board check them for continuity and replace if blown with ones of the same values
look at the tops of the capacitors for popping they should be flat topped not bulging up replace any that are bulging
finding a supplier for you without a geographic location for yourself is not possible
also you can get the power board repaired or replaced but the power surge during the failure could have damaged other components making it cheaper to replace the whole TV with a new one
Posted on Dec 28, 2016
pizzaguy3274
  • 4 Answers
SOURCE: 42fd9954
Not a fix, but it got my tv on.
I removed the back and tried the power switch.
I located the relay that was clicking.
I have two blue relays in the middle of my power board.
I placed a hair dryer over the relay for a few minutes.
After four tries of the power switch and it stays on!!!!!
Heat keeps the relay from just clicking off.
I don't know why.
This will at least get the tv on though.
Posted on Apr 12, 2008
  • 109 Answers
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you: http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HP-R4262&dType=D&mType=UM&vType=R&prd_ia_cd=&acc_ia_fl=&disp_nm=HP-R4262
Posted on Jun 19, 2008
robwan
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
electrotech1
  • 1126 Answers
SOURCE: Samsung model HP-T5054 Plasma TV
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Posted on Oct 16, 2010
SD Tech
  • 14553 Answers
SOURCE: Samsung Plasma tv pn43d450 tv wont turn on
If caps there not puffed or leaking voltages in and out of the power board must be checked next (right at turn on of the set) to see which come up and or instantly go off....this is the place to begin.
Posted on Mar 27, 2012
Testimonial: "Quick response thanks What could it be if its not the power board? The logic boards wouldnt do that would they "
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Panasonic plasma flashing red light
Sep 11, 2013 | Panasonic Silver Tilt/Tilting Wall Mount...
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
I currently have my 55HDX62 Hitachi Plasma wall mounted. I am moving the unit to another location and wish to place it on top of a TV Stand. I do not currently have the table stand which came with the unit...
Even you find it the shipping won't be cheap. They do make universal stands for LCD/PLASMA TVs. You may want to see at Walmart or a similar store if they carry the universal stand.
About a year ago a customer brought a 55" Panasonic plasma TV to our shop, and we asked him to bring the TV with the stand he found out his wife, trashed it and he made a nice stand out of pieces of wood. If you keep looking on ebay you may be able to it.
Best of luck
AAA TV SERVICE
Jun 12, 2011 | Hitachi 55HDX62 55 in. Plasma HDTV
Buzzing sound then dead
Most likely power supply is dead,but there is a small chance that the power cord has been burnt out.If your TV is wall mounted or left very little room behind the tv to allow it to"breath",that could happen.
So,stop by Fry's to get a power cord and replace yours and see if that works or not.If not,it is time for a repairman to do his/her work.You are right,it is not cheap.
Next brand:New Pioneer KURO plasma tv,case closed!Reliable,and top of the line.
solutiondoct
Jun 15, 2008 | Samsung SPN4235 42 in. Plasma HDTV
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Televison & Video Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
