Question about Oliso Irons
My Oliso Iron is no longer working like it used to. Not letting water spray our of the spayer. And isn't heating up as well as it did when I first starting using it. What do I do, now? Thank you,
geokohler
  • 304 Answers
SOURCE: Brown spots coming from steam iron
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
reddyanantha
  • 205 Answers
SOURCE: My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Posted on Oct 02, 2009
DiYerTech
  • 70 Answers
SOURCE: What happens if I use CLR in my steam iron?
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Jun 06, 2010
SOURCE: bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Posted on Apr 20, 2011
I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
take it back for a warranty exchange after you check that the thermostat setting is on steam
distilled water is recommended for irons
bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
I plugged my max 110 V Oliso iron into our house's only 220 V outlet. Smoke is being emitted and it is unusable (The iron, not iron). Can someone please tell me how to fix it?
are you saying that the iron works with 110 volts and you plugged it in a 220 volts outlet??? if so then the voltage is to high for the iron (luckily it didn't get burnt) but all you need to do is plug it into a 110 volt outlet
Jun 23, 2015 | Oliso TG-1000 Iron
No heat
take it to an appliance repair shop for a diagnosis of the problem
it it was new 2 months ago take it back for a warranty replacement or refund
Nov 11, 2017 | Oliso TG-1000 Iron
My iron does not heat up
The most likely cause is a faulty temperature sensor. The Iron is most likely shutting itself off because it believes that it is already at the correct heat. The less likely scenario would be a faulty heating element. In either case you will not be able to fix this yourself.
Check that the Iron is correctly plugged into a working outlet as that often tends to be the solution we all miss.
Mar 07, 2011 | Oliso TG1050 Iron with Auto Shutoff
Iron does not heat up
try to open the terminal box of your flat iron use the ohmmeter test one prod on line one of service cord of plug to line one if you got a resistance or continuity it means line one of your cord is ok together with the line 2 test it possible your cord damage or try to test the heating element if has a resistance it means good or try to adjust the setting on rotate knob or fuse busted replace it.
Mar 07, 2011 | Oliso TG-1000 Iron
Iron leaks , lift stuck in up position
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 12, 2010 | Oliso TG1100 Iron with Auto Shutoff
My oliso iron is not heating up yet all the lights go on when I plug it in and turn it on.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Nov 30, 2009 | Oliso TG-1000 Iron
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Irons Logo
132 people viewed this question
Top Oliso Irons Experts
Andrew Taylor
Andrew Taylor
ray gallant
Bill Boyd
Are you an Oliso Iron Expert? Answer questions, earn points and help others
