Question about Humidifiers
Why does my steam humidfier turn itself off and will not restart again?I have two unitS and NO INSTRUCTION MANUAL CAME WITH THE PURCHASE
Ultrasonic humidifier's fan isn't running, the light indicated red instead of blue, and there is no mist coming out. How to fix it please since we cannot afford for another one right now.
I had the same problem. Looked up the manual online. Red light indicates water level is low I had just refilled the tank so that was not the problem but manual said to make sure water tank was firmly, securely seated on base. I unplugged the unit, unscrewed the plug on the tank and screwed it back on and then made sure the tank was securely seated on the base, plugged it in and it started working. If the tank is full you may just have to make sure the tank is fitting properly in the base.
Feb 05, 2014 | Homedics Uhe-oc1 Cool Mist Ultrasonic...
Hi have a vicks warm steam vaporizer model v188. works great, just wanting to clean it. Can't find my manual anywhere.
The easiest ans simplest way to clean it, is too mix a 50/50 solution of White Vinegar & Bottled Distilled Water (enough to fill the tank) and fill the the tank with the solution. Allow it to set for 30 minutes, then turn the unit ON. Allow it to run, until the tank is half empty. Pour out the remaining solution and fill with the Bottled Distilled Water Turn the unit ON and run until the tank is almost empty. Following these instruction will remove all the lime and calcium build up in the unit.
Tip: Using bottled Distilled Water rather than Tap Water, will totally eliminate calcium and lime buildup.
I hope this helped you and thanks for choosing FixYa.
Aug 13, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
After cleaning everything the humidifier no longer runs. When I turn it on no matter what level I set the desired humidity to the green light goes on indicating that it is at the desired humidity. Before...
The humidstat controler has failed. By cleaning the humidfier you introduced moisture into the system. Dry the humidstat controler with a hair dryer and try the humifier again. If the unit still does not shut off at maxium setting. Replace the humidfier controler.
Jan 26, 2011 | Hunter 32300 Humidifier
I have a Honeywell humidfier HE 220A with a KIP U147112 pump. A lot of water bypasses the humidifer and I use 5 gal. in 24 hours. is there an adjustment on the pump to reduce the flow, or some other...
I have a Honeywell humidfier HE 220A with a KIP U147112 valve. Will turning the large screw head on the valve decrease the volume of water flow through the humidifier. Too much water is being wasted.
Dec 20, 2010 | Honeywell HE220A1019 Whole House...
My vaporizer is making a quiet bubbling/gurgling noise. This is only the second time that I've used it, but I can't seem to find the instruction manual. What could this mean?
That is very normal...the sound is the water being turned to steam which is the "vapor" that comes out...
Everything is okay and perfectly normal.
heatman101
Mar 30, 2010 | Vicks V150 Humidifier
Knocking nosie when water enters humidfier
That would the the 24volt soleniod valve that the water line attaches to. Steve
Dec 20, 2008 | General Filters 1042-LH Humidifier
Humidifiers Logo
50 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
