I have a lux 500 thermostat and i changed the batterys and now it is reading in fahrenheit and i can not get it to read in celsius can you tell me how to put it back to celsius
mastatech
  • 478 Answers
SOURCE: AC Thermostat
If you have a maual go to the installer settings, Most manufacture have these manuals online
Posted on Mar 25, 2009
  • 4 Answers
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Posted on May 05, 2009
  • 114 Answers
SOURCE: the air temp reads in celsius, how do i change it
thereshould be some buttons groupped together on thedash gas mileage is mph/kilo air temp cel /fer push the button until u find the readings readable foryou
Posted on Jan 24, 2010
SOURCE: I need to change my Maytag oven from celsius to fahrenheit.
I had the same problem, after multiple calls to maytag I finally rec'd an answer. I feel your frustration, didn't need a service call for this.
On my model hold down the keep warm and cancel button for 3 seconds and it will change it.
Hope this helps!
Posted on Mar 22, 2010
heatman101
  • 43501 Answers
SOURCE: How do I switch the
Hi, The procedure is fairly simple.... the easiest way is for you to look up the manual and have the proper steps right in front of you...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Nov 07, 2010
Testimonial: "thanx"
2004 Hyundai, how do I change the thermostat reading from celsius to Fahrenheit?
The climate control head defaults to Celsius anytime power is lost (e.g.dead battery). To toggle, hold in the ambient temp button and the cooler temp button at the same time. The temperature scale should switch after a few seconds of holding.
Jun 12, 2017 | Hyundai Cars & Trucks
Tip
Lux Thermostat 500
The Lux 500 Thermostat is an affordable programmable thermostat that gives you a very easy way to customize your heating and cooling temperatures to your schedule. The programming of this thermostat is easily the simplest that I have found in a programmable t-stat.
The Lux 500 series thermostats are a great economical way to reduce energy and utility expenses by raising or lowering your temperature settings a the times you set. The installation is so easy that most any DIY’er can install this thermostat. It has an easy to read display and the rotary dial makes the programming very user friendly.
A few of the other great features of this unit are, a keyboard lockout, and an air filter reminder.
This thermostat can be used on any 24v AC or 750mV single stage conventional heating/cooling system. Single stage heat pumps without auxiliary heat will also work with this thermostat.
Here is a summary of the features of this thermostat
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • 5 - 2 Day programming
  • 4 Periods per day
  • Large easy-to-read display
  • LUX patented user-friendly Speed Dial®
  • Filter usage monitor and alert
  • Default Energy Star approved program
  • Temporary Temperature Override
  • Temperature Hold
  • Keyboard Lockout
  • Temperature Calibration
  • Swing Settings #1 - #9
  • Fahrenheit or Celsius temperature Scale
  • 12/24 Time Format
  • Low Battery Warning Indicator
  • Mercury Free
As you can see this thermostat will give you a lot of great features at an affordable price.
on Jan 16, 2010 | Heating & Cooling
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
How do I switch the honeywell RTH4300B thermostat from reading in Fahrenheit to Celsius?
To start you have to push and hold the up and down buttons simultaneously until the screen displays "setup" across the top. There will be a number on the left, and a number in the right. Press the UP arrow until the number on the left reads 14, The number on the right should read 0. Press the DOWN arrow to change it to 1. Once this has been done you can press the RUN button to save the changes, and exit the setup screen. Your display will now read Celsius,
Apr 18, 2013 | Honeywell Programmable Thermostat Heater
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
Thermostat read out changed to cel instead of faren. .. How do I change it back?
hello cwest.... If your thermostat is reading Celsius instead of Fahrenheit press the 'Set Time' & 'Hold Temp' buttons at the same time to toggle it back to read Fahrenheit again.
J.
Jul 16, 2011 | White Rodgers 0754-1 Electric Water Heater...
How do you change the tempature reading for the air conditioner from Celsius to Farenheit?
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit.
Feb 03, 2010 | 2004 Kia Optima
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
