Question about Amazon Fire TV Stick
How long should it take to update my new fire stick
I am trying to install it for the first time and so far it has been checking for updates for 20 minutes
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
Jul 03, 2017 | Televison & Video
On my Amazon Fire TV, have trouble getting YouTube....streams broken up voice and video...how do I fix?
Hello Susan,
Have you tried doing any updates to your Fire TV Stick? Go to settings- system- about- check for system updates- you will get a warning about using the original power connector and wall outlet. I'd recommend using it if possible.
Apr 14, 2017 | Amazon Computers & Internet
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Has software rev 6.3.4. How can I determine whether it needs mandatory software update?
A new, free software update available for your Kindle Fire HD 7" (2nd Generation). This update automatically downloads and installs on your Kindle Fire when connected wirelessly; however, you can also manually download the software and transfer the update to your device via USB cable.
Swipe down from the top of the screen to open Quick Settings, and then tap More.
  1. Download & Install Software Updates Automatically.
Swipe down from the top of the screen to open Quick Settings, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update. After the restart, the message"Kindle is upgrading" will appear on the screen.
Mar 19, 2016 | Amazon Kindle Fire HD
I want to jailbreak my Amazon fire stick
Hi Jimmy
I guess you need to do some research on the internet then.
This site helps people to fix real faults.
We don't advise hacking (jailbreaking)
Good Luck
Mar 01, 2016 | Cell Phones
Problem with getting tv to fire up, takes about 20 minutes of pushing power button to start.
Recent Fire TV software updates causing blank screen issues
www.aftvnews.com/recent-fire-tv-software-updates-causing-blank-screen...
Aug 17, 2015 - Ever since Fire TV software update 51.1.6.1 and Fire TV Stick software update ... update, Fire TV devices now enable HDCP immediatly at boot up. ..... I'm still getting this blank screen issue on one of my TV's but not the others.
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five easy steps. ... How to Get Your New Fire TV Device Up and Running .... I'm not sure why this is not an issue for Chrome Stick, et. al but I invite you to ...
Report Amazon Fire TV / TV Stick Playback issues here - Plex Forums
forums.plex.tv > Google TV & Amazon Fire TV
Jan 10, 2015 - Indicate if your problem is for the Fire TV/ TV Stick or both, if the FireTV, .... when playing files back, i'm getting the same freezing issues regardless of ..... to have to refresh content about 25% of the time when I first fire up Plex.
Jan 10, 2016 | Televison & Video
40A3-0000-0080-0300-8007-0070
Try to clear your system of the most recent patch:
"Solution 6: Delete and then re-download system updates
To delete and then re-download the system updates, follow these steps.
Note These steps delete system updates that are installed on your Xbox console.
  1. Press the Guide button and then select Xbox Home.
  2. Select settings and then System.
  3. Select Storage.
  4. Highlight your storage device (but do not press A to select it).
  5. Press the following buttons in the following order:
    1. Left bumper
    2. Right bumper
    3. X button
    4. Left bumper
    5. Right bumper
    6. X button
  6. On the Delete System Update screen, select Yes.
  7. After your Xbox console restarts, select OK to download and install the system update.
  8. After the system update is installed, re-download your Xbox Live profile and try to sign in to Xbox Live."
You may also be out of hard drive space if you're using a 4gb internal model Xbox 360. If you haven't already, find yourself a compatible USB thumb drive to insert, format and use as added memory.
Sep 07, 2014 | Microsoft Xbox 360 Console
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Abit AW8-MAX Motherboard
I have a BD-HP20U Blu-ray disc player. I have downloaded the software update but the player will not recognize the file on the USB device. I have followed the directions very closely and have re-tried...
I had the same experience, trying several different USB sticks with different capacities to see if it would make a difference.
What DID make a difference was resetting the BD-HP20U to factory settings, and THEN installing the update from the USB stick. This time, the unit recognized the file on the USB device and installed the update.
Apr 12, 2008 | Sharp Televison & Video
Not Installing XP SP3 Updates Given By Microsoft KB 936929.
if you don't want to install those updates you should have switch off your automatic updates. the problem is the your computer might not be compaitble with the update which was sent to you.XP SP3 have a higher system and hardware requirements than xp sp2. in order to resolve your problem you need to run your xp sp2 and press repair instead of format in this way it can return to your original system. you can also try the system restore press the start, all programs look for the system tools then system restore check what date you installed this sp3 then select the day before you installed this in order for you to return to your original operating system. hoping that this will help you, expecting your positive response.
Dec 14, 2007 | Microsoft Windows XP Professional With...
Amazon Fire TV Stick Logo
Top Amazon Televison & Video Experts
john cordey
john cordey
Thomas Stauber
Thomas Stauber
Ron Harvey
Ron Harvey
Level 1 Expert
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
