Question about Refrigerators
Is there a recall on model # RB195ZABB
My freezer dosen't freeze but everything in my fridge does. Had repair guy out 3X
philipp
  • 217 Answers
SOURCE: Freezer is over-freezing
the possible cause is the temperature sensor or thermostat is not working, maybe its switch is stuck up on ON position, it looks like a wire attached to the area where ice is building up, it is connected to a switch to turn off the compressor thus controlling the operation of your freezer. replace with new thermostat will solve the prob.
Posted on Aug 23, 2007
  • 88 Answers
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Posted on Dec 06, 2008
abhishek33
  • 1239 Answers
SOURCE: Fridge stopped working, freezer still works
HI
If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 1:
Unplug the refrigerator.
Step 2:
Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3:
Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4:
Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
Posted on Dec 07, 2008
  • 20 Answers
SOURCE: fridge freezing everything
If your fridge is freezing to much put the thermistor closer to the fins (it will make it colder so it shuts off sooner)
Posted on Feb 02, 2009
SOURCE: the fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Posted on Feb 06, 2009
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
My ge profile bottom freezer refregrator is freezing everythin
is it freezing everything in the fridge as well? if so i had the same problem with my side by side fridge a while back. the appliance repair man told me to vaccuum the fridge underneath and all the other parts behind i did and it seemed to work well after that. also have you checked your temp controlls in the fridge.
Jan 02, 2013 | GE Refrigerators
Hi my Samsung fridge is freezing up? What do i do?
samsung fridge freezer problem click here
hi what model do you have - if its the american style one
fridge freezer up is a common prob with samsung
you could have a look on youtube - there a guy who has a dedicated youtube - samsung fridge freezer repair channel
heres one of the videos >>>>>>ebay links below videos where you can pruchase spares
hope this helps , if you require parts look under youtube videos as there are links you can click onto that will take you to this guys ebay samsung spares shop ..">
Dec 28, 2010 | Samsung Refrigerators
Is Model MSD2556AEW one of the fridges being recalled? Our fridge has stopped freezing in the freezing but is cold. The fridge is warm.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Can't find a recall on that..
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Refrigerators
Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
Everything is freezing. Local repairman says the
Hi, what he is talking about is panel in the vent from the freezer to the fridge. Basically when you want the fridge colder a little panel (damper) inside the vent opens and allows more cold air in the fridge. When you want it warner the damper closes and allows less cold air into the fridge. This damper is controlled by the fridge control. What your repair guy is saying is the door is stuck in the open position which is allowing too much cold air into the fridge and freezing the food. if you have any other questions please feel free to comment. Mike
Dec 20, 2009 | GE PSS29NHNWW Side by Side Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Freezer working fine, Fridge is freezing everything on low settin
THERMOSTAT ON 90% OF SIDE/SIDE REFRIGERATOR IS LOCATED AT THE TOP OF THE FRIG COMPARTMENT .YOU KNOW, THE ONE THAT HAS OFF ON IT AND USUALLY NUMBERS. YOU WILL HAVE TO DROP THE PANEL TO ACCESS THE THERMOSTAT. ALSO NOTE THAT AN INDICATION OF A STUCK THERMOSTAT IS WHEN THE COMPRESSOR RUNS AND RUNS AND DOESN'T SHUT OFF.ALSO CHECK FREEZER TEMP TO SEE IF IT IS BELOW 0 DEGREES THAT ALSO INDICATES STUCK THERMOSTAT.
Jul 25, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Aug 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
