Need to change user of this notebook. I got this used and need to have it set up for me
I have an Omni Book 500 That wont let me change the bios is there someway to get around that ?
I am guessing that you are attempting to use a non supervisor level password. There is usually a facility to set both a user (restricted function) password and a setup password (administrator rights access). You may need to reset the passwords within the bios setup.
Apr 10, 2014 | HEWLETT-PACKARD Omnibook 510...
How to unlock dell inspiron mini laptop notebook
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Oct 29, 2011 | Dell Inspiron 1501 Notebook
I tried to change permissions on my hard drive and now I am unable to have access to anything other than just opening programs and folders.
Enable the administrator account, login as administrator and select your regular users folder and assign your regular user as owner.
Enable admin Open a cmd prompt, run as adminif in win vista/7 type without quotes "net use administrator /active:yes" Log out of current user and login as administrator
Now you should have permission to set permissions to your other users folder. Set ownership to originsl user.
Comment if you get stuck or need more help
Aug 05, 2011 | Acer Aspire 5050-3242 Notebook
Hi need to get bios password for aspire 9304 can anyone help
Hello thefall,
if by chance you didn't 'create a "Supervisor Password" to prevent anyone from changing the configurations in the BIOS / CMOS Setup?
Bootup / Restart the computer, and follow these steps:
  • When you hear the computer start-up, there will be a message that flashes very quickly at the bottom of the screen, it will read!
  • Press F2 or F12 'or on other' Computers, the 'Key' Sequence may be [F11]..."
  • The area of your attention, will be [F2] Key at the top of the keyboard.
  • Press the [F2 Key] to open the CMOS / BIOS Setup. paul7of9_15.jpg
  • Once this screen appear!
  • You will see a 'Listing" of different set-ups.
  • There will be instructions in the [right] Help ? area.
  • You be using the "Arrow Keys" to (Select and Choose Items).
  • In the first screen, there will be on the (right of the screen).
  • Set Supervisor Password = This is the "Password Setting that will prevent anyone from getting into without authorization!"
  • To "Change or Configure" CMOS or BIOS setting.
  • Set User Password = This Password is use for "Logins / User Accounts...
  • You want to "Reset or Change the Supervisor Password.
  • Do so; and to finish, 'press' the [F10 Key] to 'Save the Changes.'
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 27, 2011 | Acer Aspire4720 14.1-inch Notebook PC PC...
I need to reset password on my new samsung laptop
Forgot your Windows password? moz-screenshot.pngYou can create a Windows password reset disk to reset your lost or forgotten Windows password, i have created one with the tool Windows Password Breaker and reset my administrator password successfully.
Dec 14, 2010 | Samsung P30 Notebook
Clear password hdd
If you know your hard disk password, then go to the BIOS configuration and then to the password/security section and then to the hard disk password setting. You need to enter the hard disk password and then you can select disable hard disk password.
Nov 13, 2010 | Acer Extensa 5620 Notebook PC
I want to change chinese language in english i need some real link to get software
In Windows XP, you can set the language that the default user on the local machine (or a domain user that doesn't have a profile) will see at first first log on. It is also the language that is applied to system services running on local machine.
• Open Regional Options in Contol Panel
• Click on the Advanced tab
• In "Default user account settings" at the bottom of the page, check the box beside "Apply all settings to the current user account and to the default user profile"
Jan 31, 2010 | ASUS Eee 4G Notebook
My hardrive crashed. now my big fish games wont work. it tells me to use a administrator account. what is that
You have tow types of account for users. One is as an administrator that has privileges to change settings on the PDC/ laptop and the other is a user who can’t change system settings etc. Both types of user can play games and run applications but the user can only run certain types of apps. The user can run admin apps by right clicking the executable or shortcut of an app that needs admin privileges and then select Run as Administrator to work around the problem when it arises.
Sep 30, 2009 | Dell Inspiron 9300 Notebook
Forgotten passwrod to access user account
If you can log in as an administrator or someone with administrator rights you can open the documents folder for all users. If you need to make a new user. (if possible) and set it to administrator rights. Then log in under the new name and open "my computer" then open the folders as follows.
C:\>documents and settings>User>users documents
Does this help? If so please don't forget to rate the solution
Feb 02, 2009 | Compaq Presario Notebook
I forgot my Administrator Password
email me at: fixya-expert@live.com then i will send instructions how to remove or change it
Mar 08, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
