Spt dishwasher does not start
The lights are on but machine does not start when I press start.
Why won't my dishwasher door close?
The screws that hold it in place could be a little too tight. That would bow the frame just enough not to let it latch
Nov 07, 2014 | SPT Portable Dishwasher SD-9241SS -...
Spt dishwasher not draining
Drain the dishwasher yourself. Then hose it out using a hose. most of the time the draining part is clogged from food debris. I called spt and they told me to buy another one. SO I took the dishwasher out side and decided to hose it out to get the food out that was stuck inside the drain. Make sure to take out the inside removable parts. It has worked fine since
Dec 10, 2013 | Sunpentown Spt-sd-2201w Countertop...
Electrolux (dishlex) DX302SJ dishwasher all lights flashing. When I press program and start buttons together code 1C flashes.
Take the kick panel off the bottom. There is a tech sheet in an envelope under the machine. IT will have everything that you need to do to troubleshoot the machine.
Dec 02, 2013 | Electrolux Dishwashers
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Indesit DI 620 dishwasher lights 2 and 4 flashing
Lights 2 and 4 flashing - can't start machine. This fault not covered in manual.
Apr 21, 2009 | Maytag MDB5100A Dishwasher
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
