Do they sell a heat element kit for rv roof a/c duo therm model 58925? I haven't been able to locate one.
co7196
  • 3433 Answers
SOURCE: Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Posted on Oct 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
Posted on May 10, 2010
  • 266 Answers
SOURCE: RV Dometic Duo Therm roof top AC w/heat pump Model
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Posted on Aug 08, 2010
  • 713 Answers
SOURCE: AC roof mount in RV going on and off. I have been
yes it is and you will have to order party from net.
Posted on Feb 16, 2011
  • 8404 Answers
SOURCE: RV AC is working fine,
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Posted on Jul 26, 2011
Is it common for a rv rooftop air conditioner to leak water on to the roof? I have a Dometic Duo-Therm unit 579,590,595 series.
All AC units create condensation from the cooling of air (cold/cool air hold less water than warm air), it is worse in areas of humid air like the Midwest for example.
May 12, 2017 | Dometic Heating & Cooling
Can I recharge a Duo Therm 600315.001 RV Roof mounted air conditioner? It uses R22 refrigerant. If not, where can I find a replacement or can it be serviced somewhere?
I would suggest that you visit an ac specialist shop as all air conditioners( car, truck , house and yours all use the same principle of operation
because it is roof mounted in an RV may be a caravan repair shop that has an ac specialist in the workshop or a truck service shop that installs ac units in truck cabins would be a good place to start
Mar 13, 2016 | Dometic Heating & Cooling
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Installing rv roof airconditioner heat strip
May 09, 2010 | Heating & Cooling
Sep 28, 2009 | Heating & Cooling
Duo Therm AC/Heating not working at all after tripped breaker.
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Jul 20, 2009 | Heating & Cooling
Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Aug 05, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
