Question about Dishwashers
Indesit IDL500 door wont close properly, catch appears to be the problem?
  • 28 Answers
A lever inside the door lock is attached to a spring. If the lever or spring is broken, it wont lock.
Posted on Jul 27, 2009
Indesit IDL500 not heating (element is fine)
It's usually behind the control panel you have to remove the screws on the door
Jan 03, 2018 | Indesit 24 in. IDL500 Built-In Dishwasher
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Dishwaher not working
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit IC70C Condensor dryer
We experienced a similar problem and corrected it by closing the drying door and then hitting "OPEN" followed by closing. Sometimes we use a tool to release the catch and then close the door. We have not seen this problem return.
Nov 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Indesit IDL530
it will require the door outer casing to be removed and the control panel to be removed as the lock assembly is fitted to the control panel,please make sure appliance is disconected from the mains supply as there are electrical connections there.
Sep 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Spares for Indesit IDL500 Dishwasher
My dishwasher will not heat up to temperature during cycles. Water remains cold, what parts could be a problem and howwould I test them
Aug 02, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Green flashing lights , what does it mean ?
I have an Indesit IDL 500, the machine will start fine but after about 20 mins the Ist and 2nd button start flashing. Can you help?
Regards
Ingrid Houben
Jul 06, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
454 people viewed this question
Top Dishwashers Experts
