Question about Refrigerators
I need wiring information for an integrated fridge John Lewis JLBIUCL05
I have an integratated fridge, John Lewis JLBIUCL05 (made by Electrolux), when pulling out the fridge, the wire caught and the spade connectors pulled off of the electrical connnector block on the compressor terminal block, about a dozen spades. I need a schematic to tell me where they need to be connected. Thanks
simplemitch
  • 752 Answers
SOURCE: CDC-R304
red = 12 volts switched (ignition)
yellow = 12 volts constant
black = ground
blue = power antenna
blue/ white = amp turn on
purples = right rear
grays = right front
greens = left rear
whites = right front
black striped speaker wires are negative side
Posted on Nov 09, 2007
  • 1861 Answers
SOURCE: Need connector block connections for horn wire,relay to button.
The horn switch provides a ground. If you have no voltage at the horn wire, inside the steering whel, I would suspect a bad spiral cable, or clockspring under the steering wheel.
Posted on Mar 04, 2009
louislevel_2
  • 374 Answers
SOURCE: Wiring a Husky brand compressor from Home Depot.
hi! there,
you can use terminal connector like on figures83ba8af.jpg joint connector or lug connector
this are more convenient to use
easy to install and has insulated for connection.
insulated ring terminal connector
this is also good for connector more safe for circuit breaker suipply.
go to the nearest hardware or mall
Posted on Apr 20, 2009
hardinfarms
  • 144 Answers
SOURCE: when removing starter it dropped and pulled a wire
Posted on Oct 02, 2009
SOURCE: how to wire a harry moss air horne relay to
If the compressor has 3 air connections on top then the two lower terminals with nuts are the + and - supply inputs to the compressor motor. The two top spade terminals power a solenoid valve which changes a triple sequence (illegal?) to a combined blended triple tone. I don't think polarity is an issue but to check this connect a 12V battery -ve to the mounting bracket on the compressor. Attach 2 wires to a headlamp bulb and connect one to battery +ve. Then touch the spare wire to each of the 4 terminals in turn. If the bulb lights that terminal is at compressor ground. You can determine the operation of the relay in the same way. Between 2 terminals the relay will operate. Note those and then test each to the relay bracket to see if one side of the coil is grounded. By powering the relay directly from the battery you can then use the bulb to determine which contacts are 'made' when the relay operates. You will need a relay to control power to the motor. The solenoid valve probably only takes a couple of amps. You could run both the motor and the solenoid valve from the same relay if you just wanted a blended composite tone.
Posted on Sep 30, 2010
I have a JOHN LEWIS slimline dishwasher JLDWW906. It is showing error i60 which is not in the manual water pressure is fine as is drainage. Can anyone help?
Hello, Isa -
I suggest you contact the John Lewis company directly and ask what the i60 error code means for your model of dishwasher.
This is the link to the Contact Us page for the John Lewis company:
https://www.johnlewis.com/customer-services/essential-information
Best wishes.
Mar 07, 2018 | John Dishwashers
What size needle does a John Lewis mini seeing machine need?
hi Janet.
all i can find out is,ebay sells all john lewis needles.so if you go there and put in your make and model number it might find the size you are trying to find out.
or again go on the the google page and put What size needle does a John Lewis mini sewing machine need. but make sure you put your model numbers or any other numbers you can find.on there as well.
Dec 06, 2017 | Sewing Machines
What Does Error Code E90 mean on a John Lewis Washing Machine JLWM1202 made by Electrolux
How should anyone know? Go to the web site and find out so you can be guided accordingly.
Sep 17, 2017 | Electrolux Washing Machines
John Lewis Fridge Freezer - Freezer compartment is working, fridge light works, but the fridge is not working. Please help!
Leaving the freezer door open for extended period of time could have caused the evaporator to freeze up and prevent cold air being driven into refrig compartment. Unplugging it for 24 hours will give it a great chance to unfreeze. You can also check the freezer temps before you do this - bet they are no where close to the ideal of zero degrees since the ice buildup is an insulator and prevents the freezer compartment from going down to the correct temps. And if the freezer is not at least 10 degrees or less your ice maker, if you have one, will not work since it has a thermostat that only cycles the ice maker at 10 degrees or less.
Jul 23, 2016 | Frost Refrigerators
Hiow do I remove an integrated fridge
Hey friend, thanks for your inquiry!
I see you want to remove an integrated Electrolux refrigerator. Could you please provide a model number for your appliance? With that information I can better assist you. -Matt
Aug 27, 2014 | Electrolux Refrigerators
How to assemble john lewis square cot
My product arrived without an instruction manual, so how can I get a copy?
From the John Lewis website - http://www.johnlewis.com/
"Some products have an instruction manual in a downloadable PDF format on the product page. Please check if this is available first, but if it's not, then call or email us and we'll be happy to help."
LINK to request pdf:
http://www.johnlewis.com/customer-services
LINK to "cots" page:
Cot Beds ' Baby Cots, Baby Cot Beds ' John Lewis
http://www.johnlewis.com/baby-child/sleeping/cotbeds/c80000610
LINK to video demonstrations:
(John Lewis travel cot video demonstration)
http://www.johnlewis.com/inspiration-and-advice/family/john-lewis-travel-cot-demonstration-video
May 28, 2014 | Toys
John lewis integrated dishwasher
make this test and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Jul 24, 2013 | John Lewis JLBIDWS1804 Builtin Dishwasher
User manual for john lewis tumble dryer jldv08
Hi I need to find an instruction manual for my tumble dryer John Lewis JLDVO9, no-one seems to do it anywhere! Someone please help
Oct 18, 2012 | Dryers
I need an instruction manual for John Lewis JLSS1814 Fridge Freezer
Download your manual here :
https://sitel-johnlewis.custhelp.com/ci/fattach/get/1908/1276677358/redirect/1/session/L2F2LzEvc2lkL0V6UXBwTWhr
Regards
Dec 17, 2010 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
