Question about Kenmore Washing Machines
All the lights come on but I can't change any of the settings
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 38 Answers
Is the door closed? Did the last load finish normally or did you get an error code? Has the filter been cleaned? I'll probably need some more info to help you figure this out like the age of your machine, top or front load, etc... Thanks!
Posted on Dec 28, 2016
We purchased a 6' Artificial Holiday Fiber Optic Snowflake Light Christmas Tree with the understanding that the light functions have 8 settings. How do you change the setting?
Not enough information, but usually the setting is changed by keeping the "ON" button down for a few seconds. This usually cycles through the various settings. Sorry, can't really help much without more details.
Nov 26, 2016 | Electrical Supplies
Why does the Change Oil light stay on 15 seconds after starting car?
Try re-setting the oil change light and see if it quits. Should re-set itself. Not oil sending unit, that tells computer and light when there is a problem like no oil pressure.
Sep 02, 2014 | 2003 Chevrolet TrailBlazer
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
How do i set the time?
To change the time you hold the light/set button. It may take some fiddleing but the seconds should blink first. Then you push the lap/reset button to move to a different part you want to change. You push the start/stop button to change the time. Then you push the set/light button to get out of change mode. Hope this helps set-time-vvbd02rb5wmmvmiwlulx4lsd-1-0.jpg
Mar 25, 2013 | Nike Triax WK0006-001 Watch
How to set time on adidas adp6011 watch
1) Press "SET/LIGHT" (top-left) button for 4 seconds.
2) Press "MODE" (bottom-left) button to reach blinking hour/minutes (~4 times press)
3) Change whatever you want (Hour/ minutes/ seconds/ date)
4) Press "SET/LIGHT" (top-left) again to set whatever you changed.
May 27, 2012 | Adidas Watches
Internet works, but wont work with wireless power light lights, internet light lights, wireless light does not light
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 31, 2011 | Linksys Wireless-N WRT150N Router
Change day light savings setting on old t311t
It won't understand. It was mfg before the new change
Feb 28, 2010 | Timex T311T Clock Radio
Oki 320 turbo, serial interface, how do I change
To change the settings, make sure you have a good ribbon installed.
Press the MODE button. The SEL light will go out. Menu light will come on.
Press the GROUP button until the printer prints something like:
Serial Interface Parity None
To change the Parity, press SET. A new line will print as:
Serial Interface Parity Odd
Press SET until the Item is the one you want.
Then Press the ITEM button. It will then print:
Serial Interface Serial Data 7 or 8 bits 8
Again if you want to change it, press SET. Otherwise go to the next Item.
Continue using the ITEM button to choose the item you want to review or change and the SET button to change the selection.
When you have made all the changes verify by going through all of the items with the ITEM button. When you are satisfied, Press the MODE button to save all of the changes. (The Menu light will go out.)
If you have any trouble Comment back.
Thanks for using Fixya.
Aug 11, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Tocco backlight not staying on.
Menu > settings > display and light settings > light settings > backlight time > dim> change time till dim upto 3 mins. back >on >change time light stays on .
Jan 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
i think you changed you handset s light settings...
so change it to automatic so the light active during the call will be handled automatically.......
once you change that light settings to automatic then phone will control the light settings so that when you are active on call for some seconds the backlight will be active after that it will get off automatically...
Feb 12, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Open Questions:
Washing Machines Logo
24 people viewed this question
Sal De
 Brian Main
Brian Main
