Question about Home
My HM clock has automatic stops when winding the cable driven weights up. The movement will only operate for a day and half before hitting a stop and the clocks. How do I correct this?
SOURCE: Sharp Atomic Clock
I have a sharp atomic clock that once set for the exact time, after a day loses 3 hours.
Posted on Sep 18, 2008
SOURCE: repair of battery-operated wall clock
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
Posted on Sep 20, 2008
Niraj Limbu
  • 183 Answers
SOURCE: times of day clock stopped
you are experiecing with your CMOS battery so:
try taking the CMOS battery out
leaving for 30 seconds
make sure it's all unplugged from the wall
do that first
then press the power button after the 30 seconds
to drain all power
then put battery back in
and plug in and turn on
and if still problem remains then you need to change your CMOS battery.
Thanks and do not forget to rate answers.
Posted on Jan 01, 2009
  • 10406 Answers
SOURCE: My laptop says Time -of -day clock stopped when i turn it on
It sounds like the battery on your computer is dying, and the battery cannot keep the clock running. If Dell's warranty is still valid, contact Dell, to get your computer fixed/replaced.
Posted on Dec 08, 2009
proton77
  • 1183 Answers
SOURCE: time of day clock stopped - DELL Inspiron 1525
This is one of the known issues with the Inspiron 1525 computer.The problem is caused by faulty cmos battery. If you computer is in warranty kinldy call Dell to get the same replaced . if the system is out of warranty. You would need to replace the CMOS battery ie below the keyboard.
You can follow the instructions below
http://support.dell.com/support/edocs/systems/ins1525/en/SM/coinbatt.htm#wp1179839
Thanks
Proton
Posted on Feb 06, 2010
Fossil blue bq9307 Watch stopped, how do I get it running again? I'm told it winds automatically with wrist movement, no battery? Thanks for any help you can give
If it an automatic watch, it usually marked as such on the front or back.
To wind a self winding watch, shake it gently from side to side for a few minutes.
This type of watch thrives on use and if left off for more than 2-3 days it will stop.
Feb 07, 2011 | Watches
Tip
Cuckoo Clock Repair
CUCKOO CLOCK
REGULATION AND REPAIR TIPS
REF: 30 hour and 8 day clock
[From my shop notes:]
{FACT}
-1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
REPAIR TIPS:
1. Recommend regular servicing every 2 to 3 years for these unique clocks, mostly due to the fact that the movement is open to the elements (dust and dirt is easily deposited on the movement).
2. Sometimes the clock is "over weighted", meaning that the actual weight is to heavy for the clock. I have seen some very new clocks with the wrong weights added. Instead of the clock simply stopping after the lubrication qualities are gone it continues to run and ruined the bushings.
-To find the correct weight of a newly serviced clock, you can use a small scale. Anchor it to the floor, connect chain to the top end, wind it until it is more than double the weight of the existing weights, and then start the clock to running after the clock stops running, X's the weight figure on the scale by multiplying 1.25 or 1.35 X's the weight figure on the scale by 25 to 35 % maximum = the amount needed. [Example scale indicator is on 1 lb x 25% = 1.25 lb
BELLOW REPAIR:
-Unfortunately many repair persons have opted to simply replace the bellow, this is unfortunate because it can so easily be repaired.
-I use a "RE-COVERING BELLOWS" kit.
-This kit comes with bellow replacement material, glue, one wooden handling tool and great instructions.
DO NOT attempt to simply patch work this, it is not fair to the customer and it will not work long.
THE CHAIN:
If needed, don't be afraid to replace the chain as they are easily ordered and replaced. Most cost about $3 to $4 a piece.
The problems are:
-If there is a child, pet, or adult in the house, the chain can be stretched. If the chain becomes damaged, it will get hung up inside the clock. "Even one damaged link can stop the clock."
-Wrong size chain {the differences between 72 links per foot and 67 links per foot are easily confused). Recommend actually laying the chain on the chain drive gear and seeing if it fits.
MUSIC BOX GOVERNORS:image008.jpg
Clean and oil only. Check the pivots if worn. Don't waste your time to try and repair, just replace the Governor. Only the actual music drum can be sleeved with a new bushing. Cost for a new governor is about $25. Well worth having a few assorted governors in stock.
-If a complete replacement is necessary, the cost is about $40 to $50.
Hope this tip helps.
R/ David
http://antiqueclock.clockstop.com/CUCKOO.htm
on Jan 22, 2010 | Watches
Tip
Watch glossary: A
ACRYLIC CRYSTAL
The inexpensive plastic crystal. It's not very hard and shallow scratches can be buffed out.
ALARM WATCH
A watch provided with a movement capable of releasing an acoustic sound at the time set. A second crown is dedicated to the winding, setting and release of the striking-work; an additional center hand indicates the time set. The section of the movement dedicated to the alarm device is made up by a series of wheels linked with the barrel, an escapement and a hammer striking a gong or bell. Works much like a normal alarm clock.
AMPLITUDE
Maximum angle by which a balance or pendulum wings from its rest position.
ANALOG or ANALOGUE
A watch displaying time indications by means of hands.
ANALOG QUARTZ
The most commonly-used term in referring to any analog timepiece that operates on a battery or on solar power and is regulated by a quartz crystal
ANNUAL CALENDAR, see calendar, annual
ANTIMAGNETIC
Said of a watch whose movement is not influenced by electromagnetic fields that could cause two or more windings of the balance-spring to stick to each other, consequently accelerating the rate of the watch. This effect is obtained by adopting metal alloys (e.g. Nivarox) resisting magnetization.
ANTIREFLECTION, ANTIREFLECTIVE
Superficial glass treatment assuring the dispersion of reflected light. Better results are obtained if both sides are treated, but in order to avoid scratches on the upper layer, the treatment of the inner surface is preferred.
ARBOR
Bearing element of a gear (s.) or balance, whose ends-called pivots - run in jewel holes or brass bushings.
ATMOSPHERE (ATM)
Unit of pressure used in watch making to indicate water-resistance
ATOMIC TIME STANDARD
Provided by the U.S. National Institute of Standards and Technology, Time and Frequency Division, Boulder, Colorado, atomic time is measured through vibrations of atoms in a metal isotope that resembles mercury. The result is extremely accurate time that can be measured on instruments. Radio waves transmit this exact time throughout North America and some "atomic" watches can receive them and correct to the exact time.
AUTOMATIC
A watch whose mechanical movement is wound automatically. A rotor makes short oscillations due to the movements of the wrist. Through a series of gears, oscillations transmit motion to the barrel, thus winding the mainspring progressively.
AUTOMATIC WINDING
A rotating weight, set into motion by moving the wrist, winds the going barrel via the gear train of a mechanical watch movement. Automatic winding was invented during the pocket watch era in 1770 by Abraham-louis Perrelet, who created a watch with a weight swinging to and fro (when carried in a vest pocket, a pocket watch usually makes vertical movements). The first automatic winding wristwatches, invented by John Harwood in the 1920s, utilized so-called hammer winding, whereby a weight swung in an arc between two banking pins. The breakthrough automatic winding movement via rotor began with the ball bearing Eterna-Matic in the late 1940s, and the workings of such a watch haven't changed fundamentally since. Today we speak of unidirectional winding and bi-directionally winding rotors, depending on the type of gear train used.
AUTOMATON
Figures, placed on the dial or case of watches, provided with parts of the body or other elements moving at the same time as the sonnerie strikes. The moving parts are linked, through an aperture on the dial or caseback, with the sonnerie hammers striking a gong.
on Jan 11, 2010 | Watches
Purchased a grandfather clock at a flea market and need to know how to wind it. Has chains not a key.
Pull the chains ... there is a weight on one end and the other end is free. Pull the free end down which will pull the weight up. It is the falling weight that operates the clock. There are probably several weights, each weight has a different purpose. The falling weight actually operates the pendulum. You will probably have to wind the clock (pull the chain) on a daily or weekly basis depending on the movement of the clock (i.e. 1 day clock or a 8 day clock) If the weights are missing, you will have to replace them. Contact a clock repair shop in your area.
If you had a Coo Koo clock, one weight would run the clock and a second weight would run the bird. A third weight would run a music box or other clock feature.
I hope this answers your question. Congratulations on your purchase.
Thanks for visiting today.
Jan 30, 2011 | Kitchen Ranges
I have an early 1900 clock that I have to wind. I have noticed my clock stops frequently. I go to wind it and it is tight to wind so instead of over winding I tip the clock to start the ticking and the...
You can not unwind the clock yourself, because this requires proper clock makers tools and skills as well. Clock is stopping because it has not been serviced for a long time and the oil in clock has collected dust particles and getting sticky. This does not let the spring unwind freely and is a problem for all cogs and moving parts. Find your nearest clock repair shgop and ask for cleaning, oiling and adjusting. BE AWARE: If you are gonna try to unwind it yourself, you will damage the clock's movement, but most important - you can even brake or loose your fingers, as the clock spring is under unbelievable tension and once released, it uncoils lightning fast and is sharp as a razor.
Oct 28, 2010 | Seth Thomas Watches
I stop using mi nixon watch " THE 51-30" for a month and now it doesnt work.
Your watch is an automatic type which means that it is a mechanical self winding watch powered by a spring. It is wound up by a weight that moves when you are walking about and this watch must be worn to keep it operating.
If not worn, these watches will stop in 2 -3 days because the spring has run down.
Some automatic watches can be wound using the crown wheel (winder) but if yours cannot be wound in this way, then swing it from side to side gently for a few minutes and the watch will wind up.
These watches thrive on being used.
Oct 27, 2010 | Nixon 51 30 Watch
1. tends to stop if you are not wearing it 2. tends to stop at particular times ie 12.20 3. can't rewind the time past certain times
Automatic watches will generally run for 2-3 days before they stop.
I have no idea what causes the other problems.
If you want to keep it going while you are not wearing it, you can buy a watch winder, which gives it enough movement to operate the self winding mechanism.
Aug 18, 2010 | Chase Steinhausen TW-381-G Classic...
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
New automatic watch keeps stopping
You can wind this watch until it is snug. If it does not continue to run during normal wear then you should have the watch looked at. The swing weight or main spring maybe malfunctioning. If you can return it under warranty that would be best.
Jan 31, 2009 | Invicta Automatic Watch
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
