Question about The Audio Players & Recorders
Can barely hear out of the left speaker??? Just got these for Christmas.
    Top Expert:
  • The Master
  • 12,962 Answers
Check connections and balance control if one. Otherwise take back and exchange.
Posted on Dec 28, 2016
My receiver only plays front speakers. when i put it in surround mode none of the speakers will play and the sub even in stereo mode is barely a whisper of sound. i dont have a remote for it but it goes...
you don't need a remote. to me sounds like you might have a connection problem. try and do a test tone which will send a test signal to all the speakers. starts from left to right etc. if you cant hear all the speakers you need to check all connection wires etc. hope this helps
Apr 08, 2014 | JVC RX-8000V Receiver
Crosley CR6001A: Left speaker barely audible
Hi Eric,
I understand how frustrating this problem can be. The problem can be the result of several different things. Two of them are 1) blown speaker and, 2) blown left amplifier output.
Try listening with stereo headphones. If you can hear both channels clearly, the amplifier is most likely functioning correctly. This is desirable as amp repairs would probably be more costly than a driver (speaker) replacement. Make sure you vary the balance controls while checking for output on both L and R speakers. If the sound is intermittent, the volume or balance control may have dirt built up and may return to working properly by liberally spraying electrical contact cleaner around the stem (knob removed) with the unit unplugged. Use the extension tube to pinpoint the output along the stem. Be careful to keep from over-spraying as it may damage plastic and wood cabinetry. After spraying, rotate the knob fully back and forth several times and then plug back in and try for sound again.
If you can't restore the volume to the left speaker, you may have a blown speaker. This usually happens as a result of excessive volume which leads to distorted sound. If played this way long enough, damage to the speaker is unavoidable.
The speaker can not be fixed - but may be replaced. Replacing the speaker is something most people with conventional hand tools can do - with the unit unplugged. Finding the information on the speaker may prove to require some digging however. You'll need to know the size, wattage rating, impedance value in ohms, and frequency response. It would be best to obtain the exact replacement part if possible.
Other than this, you'll probably need to have it serviced professionally. Good luck!
Dec 06, 2012 | Crosley Cr6001a Turntable
Left speaker you can barely hear
Swap the speaker outputs from left to right and see if the defect moves to the other side. If it does, the radio will need to be repaired. If it stays on the left side...bad speaker.
for radio repair options, contact Iron Cross Audio
www.ironcrossaudio.com
Oct 19, 2011 | Harley Davidson 426290 AM/FM Radio
I can't barely hear sound from my Gateway laptop speaker m305crv? only headphones and extra speakers work! PAUL TUMINO
1. Do you have an external volume control on the side? If so adjust it.
2. Do you have a speaker symbol in your lower right hand toolbar? If so, right click on it, go to open volume control, and adjust the slides.
3. No speaker in the toolbar? Left click START, choose CONTROL PANEL, find the ikon that says SOUND AND AUDIO DEVICES, double left click it and adjust the volume.
Mar 25, 2011 | Computers & Internet
When I turn my speakers on for music...only part of the sound comes on. You can hear the music but when the singing comes on you can barely hear it.
This means that only one part of the sound is being transferred. Check the wire to check if its properly in. Also check if any wire is broken or loose. Check the power source too. ;)
Mar 04, 2011 | Dell A215 Computer Speakers
I can't seem to increase the volume when talking on the phone. I can barely hear the speaker. The volume shows it at the lowest and I can't find how to increase it.
there should be an up down toggle at the side press it up when your talking on a call. if you dont write me back with the model of your samsung mobile
merry christmas
Dec 22, 2010 | Samsung Cell Phones
I can just barely hear the audio coming from all right side factory speakers. left side is fine. all car audio is factory. No changes. Is it wiring or are the speakers going bad? Thanks
maybe the speaker is going bad but first try to replace extra speaker try to connect if still the same your car stereo is bad on the right ic output
Aug 06, 2010 | 2002 Honda CR-V
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
Speaker problem
check for the connections! unplug and plug then back! test it! if it still have the same problem then it might be at the circuitry already! maybe some electronic components were busted or malfunctioned already!
if you happen to open it! check for bulged capacitors or loose connected components on the circuity!
Nov 15, 2007 | Altec Lansing ATP 3W Computer Speakers
Top The Audio Players & Recorders Experts
tim brauer
tim brauer
Pedro Conejo
Level 1 Expert
Michel Laprise Sr
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
