Question about Saws
I need wrench for my ProTech model 4106 10 in table saw
rowdy45176
  • 2176 Answers
SOURCE: I purchased a used table saw and need a
OK first go to Searspartsdirect.com and on the right side of the site type in your model number, this will take you to another page and on the right side of this one you will see that you can view a manual, just about there what I had to do after you click on this is open a free user name account with password before it lets you download the manual, Have plenty of paper handy it is 44 pages long. Let me know if you have any trouble. I viewed it and it is there.
Posted on Mar 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: I'm looking for a manual for a Craftsman table saw model 137.2488
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606545.pdf
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 09, 2009
SOURCE: Manual for Powermatic model 70 table saw
Did you try Powermatics web site?
Posted on Aug 23, 2009
  • 7 Answers
SOURCE: I have a craftsman table
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Posted on Aug 14, 2010
puertobori
  • 7733 Answers
SOURCE: need the manual for my delta 10" table saw model
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
Where is the serial number on my black and decker table saw
You would be looking for the Model number, not the Serial number. I don't know if that will help you find the right manual. But here's something else -- a table saw is an essential woodworking tool, but without some basic instruction can be VERY dangerous. There are many sources of information about how to safely use a table saw that would all serve your son even better than having the specific user manual. There really is not all that much difference between the basic operation of any of the consumer marketed table-saws anyway.
Oct 09, 2012 | Black & Decker Saws
Manual for protech band saw#3203
I found something on amazon, take a look here: Crosman Arms Company Model 140 147 147BP 1400 Rifles Owner Manuals Factory.... I hope this was helpful. cheers
Mar 03, 2012 | Saws
Need to know how to change the agle on the blade for a protech 10 in table saw
Hi Ron,
You didn't give your model.
Protech is out of business so I could not find a user's guide for you.
The knob on the front that you use to raise and lower the blade also adjusts the angle. Depending on your saw, normally the knob releases from raise/lower mode to angle adjustment by either pulling the knob out and moving it or by pushing a lever to release it and then moving the knob.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Skil 10" Table Saw
Where can i find a new motor for a protech 4106 table saw
If you still have the old motor, use the info off of the motor label that describes the mounting configuration (this is the frame type). Do a google search for "Electric Motor NEMA Frame Sizes" for a good list of them. If your label is unreadable (or missing) search for the owners manual for your tablesaw - they usually have the specific motor model number.
The motor frame type is all you really need for making sure it will fit your saw - however, if the old motor was a 1 hp, and you install a 5 hp - you may have problems with the size of the motor hitting the table saw.
Also, decide if you want 110 or 220 volts. In general 220 is more effecient (3 phase is much more effecient). But I bet you'll want to stick with the original horsepower and voltage.
Then, do a google search for your motor. The frame for my motor is J56HC, it's a 3 hp and I use 220 volts - so my search is usually just "electric motor frame J56HC", but if I find too much garbage, then I search "electric motor frame J56HC 220 volts 3 hp". Once you find a motor model number (the motor I liked was a leeson 115048) then search for that. I found a great deal on ebay searching for this.
Dec 17, 2010 | Saws
I need to remove and replase the arbor housing from main base, any idea how to take the housing off?
on most table saws a allen wrench is needed to remove the arbor
Aug 21, 2010 | Saws
How do I change blade non model 2708 table saw?
You should have a stamped metal box-end wrench that came with the saw. Place it over the blade retaining nut, and drive the motor belt by hand to allow the wrench to tap on the table behind the blade. This will loosen the nut so that it can be removed by hand (this is a left-hand thread situation). Tightening the nut is the reverse operation and it is not necessary to drive the nut tight with a hammer--it will tighten enough during saw operation. A safety manual will say to remove power from the machine when doing this! Hope this helps!
May 24, 2010 | Saws
How to change the blade? We have one wrench, but you need two correct? Where can I buy the wrench if I need one?
Well I use a wrench on the bolt and a screw driver in the teeth against
the table to stop the blade from turning.
You could also use a vise-grip to hold the blade, just be careful if you have carbide teeth so you don't break one.
Some saws have a blade lock on the motor, I don't know about yours.
I find it best to lower the blade so its just above the table so it can be held, and the bolt is out of the way of the table.
Feb 11, 2010 | Black & Decker BDTS200 15-Amp Table Saw...
Replace blade
go to searsparts.com, have your model number ready and you can order what u need.
Jul 03, 2009 | Craftsman 10" Table Saw
Can't Get Blade Off
without a model number I cant look at a breakdown but if it is like the table saws that I work on I would assume that you removed the center plate to get to the hex nut and spindle, if so what I have to sometimes is put my wrench on the spindle and brace it against the saw frame and using a soft mallet tap on the hex wrench to loosen the nut. After this initial blade change the hex nut has to be tight but not to the point of breaking wrenches. If this doesn't work get me the model number and I will dig deeper to try and help
Jan 01, 2009 | Skil 10" Table Saw
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
