Question about Kitchen Appliances - Others
Replacement basket and handle - Kitchen Appliances - Others
I bought a chest freezer and it didnt have a basket so I bought a basket now I need to by extension handles but I cant work how the attach to the basket. it is a fisher and pyckel model h220
if you got the right basket the handles are already attached
they are either folded into the basket or lift up on the outside to sit on the edge of the freezer
Aug 15, 2016 | Fisher Freezers
Where can i get a new handle for my cookworks signature deep fat fryer model number DF-101 i know this model is years old and was wondering if they still make replacement handles
Hi Anonymous
That model seems pretty elusive to find a specific handle. That said, I've seen general purpose cookware handles for sale before that might be adaptable to your use, such as this one
Fitx All Replacement Pan Handle on Amazon. I also found here
https://answers.yahoo.com/question/index?qid=20080406162207AAx28QW that Argos is the manufacturer of the Cookworks line. Sites like this
OEM deep fryer parts the best selection from Parts Town feature a wide range of OEM parts for a number of brands, and it may be worth dropping them a note - often these are the folks who will know how many other brands that something is identical to other than a name brand (kind of like how only about 3 American companies make clothes dryers).
There are also arrays of commercial fryer baskets for sale at places such as
Fryer Baskets Frying Baskets so, you may be able to contact them as well about either replacing the basket with a proper form factor one, or perhaps about other options.
Hoping this helps, and Happy Holidays!
D
Dec 14, 2015 | Kitchen Appliances - Others
Electrolux side by side freezer baskets remove how
Hello augustus_ eli - To remove the top and/or bottom basket, pull the basket(s) out until it stops. Then, lift up on the handle and pull out at the same time to completely remove the basket. To reinstall top and/or bottom basket, align the basket with the rails and push in. The middle basket is held in place by four retainer clips; two on each rail. Before removing the basket, note the location of each retainer clip. To remove the baskets from the retainer clips grasps the handle firmly and pull up. The basket should release from the retainer clips. To reinstalled the basket place the basket on top of the retainer clips and press down.
Nov 27, 2012 | Electrolux EI26SS55GS Stainless Steel ...
How to fold peg perego 2008 Pliko P3
You also have to pull on the middle part by the basket it has like a handle.
Oct 02, 2009 | Peg Perego Pliko P3 Stroller Umbrella
I need a replacement handle for a deep fryer basket for bravetti model f1063b
Euro-pro.com is where you can find parts for Bravetti deep fryers.
They have lids, baskets, handles, heating elements and so on.
Snake
Jul 04, 2009 | Bravetti Kitchen Appliances - Others
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
Handle on basket melted
go to GE website, click on small appliances and the contact link, they can tell you how much for the basket, shipping and take your order..
Jan 15, 2009 | GE 168997 Deep Fryer
Basket Strainer Specs Question
1\ Amount of free open area is the ratio of the open area through the strainer basket to the cross sectional area of the pipe. A good basket strainer should have a ratio of 4 to 1. 2\ Ease of basket removal is important because baskets may require frequent cleaning or replacing due to buildup. 3\ Compactness of the design saves you valuable space. A small strainer is less bulky and easier to handle. 4\ Availability of basket perforation sizes gives the strainers the flexibility to cope with a wide range of particle sizes.
Aug 27, 2008 | Moen 22174 Stainless Steel 2in. Basket...
Handle is pushed out
Are you using the pressurized filter baskets? My 2 1/2-year-old SL70 recently started doing the same thing, and I think I have narrowed the problem down to the filter basket (it works fine with a non-pressurized basket). I've ordered a new pressurized basket. I can't guarantee that this is the answer, but you might try it.
Feb 12, 2008 | Solis Crema SL-70 Espresso Machine
Kitchen Appliances - Others Logo
66 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
