If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. Some BPL models use Sanyo kit. Therefore you might have to try the service mode entry method of Sanyo brand too.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Refer Sanyo circuit, since BPL will have Sanyo kit in it.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. BPL uses Sanyo Kit to their TVs. So refer to any Sanyo model set to get details about the service mode options.
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Service mode entry, adjust and exit procedure to many brand TVs are given. As BPL uses Sanyo kits, with their TVs, you can try service mode entry procedure to Sanyo too. The service mode dentry procedure will be different to set to set, according the kit used in it.
Since BPL uses Sanyo kit, service mode entry method to Sanyo should work with it. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Service mode entry method to many brand TVs including BPL models are given.
If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be
selected by the drop-down list, at the top left of the display window,
will make surf easy. You can also do a
search, by type in the brand name / model number / IC used, in the
search box at the top right of the display window. Service mode entry, adjust and exit procedure to many brand TVs are given in detail. Try the service mode procedure to any Sanyo model, as BPL TV uses Sanyo kit.
If you wish to get more details, check this
site. Pull up older posts there. Check the site with patience, as it has over
2200 posts now. All are related to
electronic equipment repair help. Service mode to many brand TVs are described in detail. Just mind, BPL uses Sanyo kit in most of their models.
