Question about Baby Gear
New baby annabel did work 1st day, now day 2 it just beeps and says A ?? Changed batteries makes no difference???? Help please
SOURCE: annabell
Have just read another review by someone with the same problem as us - Annabel shuts off after crying and they were told to only use high end batteries ie Energiser. Expensive but maybe worth a try, my little girl loves her Annabel too much not to!! Good luck
Posted on Dec 21, 2008
SOURCE: i have lost the battery cover off the baby
I contacted the maker of the doll zapf and they told me to contact the dolls hospital, so i got in touch with them.
Posted on Jun 22, 2009
  • 78 Answers
SOURCE: toshiba satellite p305-s8825 beeps 3 times on start up
http://www.computerhope.com/beep.htm it sounds like you have the "award bios" that means there is a video conflict or error.
remove any new hardware, undo what ever you did before the reboot. start there. if that doesnt work its a hunt and peck to find the conflicting hardware. remove and PCMCIA cards, then give it a try just keep disasembling one part at a time until the beep stops and begins to boot. if you dont feel comfortable disasembling anymore, its needs service.
Posted on Jun 10, 2010
SOURCE: Baby Annabell only cries tears from one eye
Hi did you get a solution to this as I am having the same problem? Many thanks
Posted on Jan 12, 2011
  • 11967 Answers
SOURCE: continous beeps when I turn
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 22, 2011
Testimonial: "thanks for the detailed information. we managed to get it to work by gently forcing the lens. thanks so much Sara"
Sony 910 baby monitor makes loud beeping when turned on
The picture you posted looks like it has the channel setting option. Notice at the bottom there are three little holes that are (as I recall) either red, yellow or green. You have to set the channel on both the transmitter in the baby's room, and in the receiver you keep with you, so that they have the same pattern of colored dots in those holes. When they have the same pattern, they're on the same radio channel. If you can hear a neighbor's monitor, pick a different color pattern to change channels. As long as both units have the same pattern, you should hear the baby, not the beeping.
Aug 09, 2014 | Sony Ntm-910 Baby Monitor
Can i get hold of flower nuts and bolts for the baby annabell carriage prem
Hi Claire,
We would recommend you contact Zapf for further assistance.
Home
Sep 04, 2013 | Zapf Baby Annabell Stroller
Insturction for how to assemble the baby annabel bed canopy.
Here is the website for Zapf Creation, they make the Baby Annabell toys.
http://www.zapfcreation.com/uk/brands-products/baby-annabell%3Csup%3EA%C2%AE%3C/sup%3E/baby-annabell-zubehoeransicht/?id=605
under product description, click on the instruction manual and it will open a PDF with the info you need. You do need to have Adobe to open PDF files.
Jul 19, 2011 | Zapf Baby Annabell 4-Poster Crib
Dec 27, 2009 | Zapf Baby Annabell 4-Poster Crib
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
Why wont baby annabell close her eyes
it must be a defect in the doll. you should either return it if possible or replace it.
Jul 27, 2009 | Zapf Baby Annabell 4-Poster Crib
I have lost the battery cover off the baby annabell that cries please could you tell me where i can pick up a new one
Jun 21, 2009 | Zapf Baby Annabell 4-Poster Crib
Annabell
Aug 25, 2008 | Zapf Baby Annabell 4-Poster Crib
Baby Gear Logo
149 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
