Question about Coffee Makers & Espresso Machines
Coffee comes out all over the place not the spout
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
  • 1618 Answers
SOURCE: We have a Talea Touch Coffee Maker and when you
First remove brew unit and clean the shower screen that is under the red gasket, then adjust the grind about 2 numbers coarser, then try making a coffee, if you have the same problem then the steam valve needs to be replaced.
Posted on Nov 12, 2009
  • 1711 Answers
SOURCE: when making cappucino coffee using
The problem
you describe it can occur if you don't perform the tablet cleaning as describe
in the user manual at page 30, (see link below).
The machine
changes the direction where the coffee will be delivered via a solenoid valve.
The coffee oils that remains inside this solenoid every time you make a coffee
they can dry out and after many coffees and if you don
Posted on Jan 09, 2011
  • 452 Answers
SOURCE: new machine but no water
we repaire 07779933829 uk
Posted on Jan 25, 2011
  • 395 Answers
SOURCE: My Tschibo Caffissimo Classic will not let coffee come out of the spout, why?
Clean the port using a small paper clip. Push it up the tube and pop out the material that collected inside.
Always use Distillate or Filtered water.
Posted on Feb 02, 2015
De longhi coffee machine- coffee pours into the middle of machine, not through spout
the main feed line ( is probably disconected to the spout ... take of the top ( screws ) and look for the feeder line normally they just put a tie rap on the edge of it ... might of come apart so now its not going true the main line and get water all over the place ;)
May 11, 2017 | Coffee Makers & Espresso Machines
Feb 02, 2015 | Coffee Makers & Espresso Machines
Coffee Is only coming out in drips not pouring.
Pump issue. You can replace the pump or get a new one. If it's new, take it back and age a replacement.
Oct 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee coming one side only of spout
There are two ways to overcome this uneven drip of coffee into the cup.
1- Make sure the machine is placed on a level counter top. The coffee drips as a gravity flow. Machine placed on a tilted surface will allow coffee flow more on the tilted side.
2- It appears the coffee faucet outlet has not been cleaned/flushed with any coffee cleaners or descaling solution. Clean the coffee outlet as following:
* Prepare two or four cups of Baking soda solution.Fill the Baking soda in water tank and make few espresso, using the preground cycle.
** Then use two to 4 cups of descaling solution and repeat the process making several espresso.
Oct 14, 2014 | Gaggia 74845 Platinum vision coffee maker...
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
How do you actually remove the spout on a Jura E8 to clean clog?
There are two parts: You will see the top part is fixed - it does not move. Remove it first, placing fingers behind the top of the piece, and gently it toward you. It will pop loose toward you - but not off. To remove completely, simple move the top half straight up, and it will release completely.
The bottom part of the spout is trickier, but equally easy once you know how it is fastened. Exam the bottom half. See how it is fastened by sliding on rails. Facing this piece, gently push leftward on the right side of the spout. The spout is flexible, and it will bow outward enough that the right side will come off its rail, enabling you to gently pull that side out. The left side will then come off as well.
Now you can clean out all the nasty.
Reverse these steps to put it back together.
Nov 08, 2012 | Capresso Jura-13187 Impressa E8...
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner ( and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
The coffee started coming out the brew spouts to the right and left and some coffee comes out in the center. i have cleaned and descaled the machine but that has not helped
I had this same problem and called Jura Capresso. They had me straighten out a paper clip and stick it up each spout as far as I could and jiggle it around (after bringing the panel with the spouts down as far as possible) Then they said to **** the panel containing the spouts up and down several times and then press the rinse button. Repeat this process several times. That did the trick for me. They said sometimes the spouts get clogged and just need to be cleared.
Nov 27, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
