Question about Coleman Electrical Supplies
Problems with a coleman 5000 maxa ER plus gen. we changed the valve that regulates the gas and the hose. The oil is fine as well as the spark plug . It still will not start. not even a little.
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: coleman powermate maxa 5000 er
it could have sezed up on you take out the plug and try to turn the motor by hand if it wont turn its sezed up,,,if so all you can do is tip down the plug hole a small brop of red x or two stroke oil and rock the motor back and frow till it frees off,,
if it frees off that is!
Posted on Aug 30, 2010
westburyauto
  • 66 Answers
SOURCE: Hello, I'm trying to get an old Coleman Maxa 5000
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Posted on Dec 22, 2010
Testimonial: "Advice was right on the mark! Well written advice too!"
al_kupchella
  • 843 Answers
SOURCE: i cant get my coleman powermate 5000 MAXA ER to
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Posted on Feb 02, 2011
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
I have a coleman maxa 5000 generator no spark
first look at the oil level some generators have a low oil shut off then remove the front cover of the engine and unplug the small wire on the side of the coil then try to start it if you get spark back the its a wire problem if still no spark then the coil is bad
Aug 15, 2012 | Coleman Powermate Powermate 5000W...
Serges up and down and stalls after a fes coleman maxa 5000 er plus
Hi mxdidit,
Surging is generally caused by carburetor problems. Squirt some carb cleaner in it and see if that helps it at all. If that helps but does not do a lot, then the carb probably needs to be rebuilt. The carb could also just need some adjusting. Check for fuel leaks around the carb and also be sure the air filter is clean.
Good luck.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 10, 2011 | Coleman Powermate Premium Plus 6250W...
I cant get my coleman powermate 5000 MAXA ER to start. i have changed the oil, refilled the gas, changed the spark plug, and tried using starter fluid. what else can i try?
Feb 02, 2011 | Coleman Powermate Premium Plus 6250W...
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
Coleman powermate maxa 5000 er - been sitting for about 2 years and I want to start it up again. Checked oil, ok. added new gas (but did not drain old). Fuel valve open, spark plug cap on. Engine won't...
Aug 30, 2010 | Electrical Supplies
I have a Coleman Powermate PRO-GEN 5000 (6250). It has been sitting for a year and the gas value was not shut off (oversite). When checking the oil, it smells like there is gas in the oil-is this possible?
when the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
Aug 03, 2010 | Coleman Powermate Premium Plus 6250W...
Powermate Maxa 5000 er will not run stably
Check the fuel filter. My company designed hybrid generators that are far more efficient. They use batteries to power your equipment, and the generator runs intermittantly to recharge the batteries when needed.
If you would like to convert to hybrid, contact me at buffalonymann@yahoo.com
Sep 24, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
29 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
