Question about JVC Televison & Video
Have lost the cursor of JVC smart 32 TV. Need the arrow !!
Instead of the arrow, the black square gets bigger and bigger and I cannot select what I want to see.
premtech
  • 934 Answers
SOURCE: JVC Channel Code locked and need to unlock
The square box is not a channel lock it's closed caption and labled CC in your menu.. Go into the menu and set CC off... No more box...
Posted on Jan 27, 2008
SOURCE: Problem with HP Smart Web Printing
I removed my HP Smart Select add-on when I suspected that it was the cause of my IE freezing up. When I reinstalled it, I had the same problem as you (no arrow for the drop down). Then, I went back to Tools>Manage Add-ons>Enable or Disable Add-ons, and I enabled "Send to One Note" and that fixed the problem.
Posted on Aug 29, 2008
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
  • 362 Answers
SOURCE: Our 32'' JVC TV model # AV-32030 has an obscured picture.
With the remote go to the Closed Caption menu and make sure it is turned off.
Let me know if this helps
Lone99star
Posted on Apr 03, 2009
  • 7993 Answers
SOURCE: TI-84 silver: Black arrow instead of line in function mode
I have answered this question multiple times. I have no idea why you calculator refuses to allow you to choose more graph styles. Maybe you should reset it by clearing the RAM.
Concerning the connected asymptotes.
In truth your function has one aymptote namely the straight line x=2 but your graph has two asymptotic branches, one tends towards -infinity, the other toward + infinity. That they seem connected is an illusion due to the finite resolution of the screen. This is made worse if you select a connected graph instead of a dotted one. I am enclosing a screen capture of the graph for the same function, drawn on a calculator with better resolution.
This clarification being given, it remains that you still have a problem since you cannot choose other styles. Do try to reset the RAM, and choose dotted graphs. If that does not work, maybe you should update the OS or reinstall it from education.ti.com.
I hope it solves your problem. If it does not, do not blame me, and remember that I tried my best.
Posted on Oct 16, 2009
Lost pass code for v-chip
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
If you wish to know more, check this link.
Jan 17, 2013 | JVC AV-32F485 32" TV
When i turn on my TI-84 silver edition only thing i see is a blinkin blaxk square on the top let corner.hiting any key wont do nothing it stays the same. Need help
If a checkerboard cursor ( black square ) is displayed, then either you have entered the maximum number of characters in a prompt, or memory is full.
If memory is full:
-Press 2nd then MEM and then 2 to display the MEMORY MANAGEMENT / DELETE menu.
-Select the type of data you want to delete, or select 1:All for a list of all variables
of all types. A screen is displayed listing each variable of the type you selected
and the number of bytes each variable is using.
-Press up-arrow and down-arrow keys to move the selection cursor > next to the item you want to delete, and then press DEL
Mar 23, 2012 | Texas Instruments TI-84 Plus Silver...
I keep getting a black square in the middle of the picture. The sound stays on and the picture is behind the black square. How do I get rid of the black square for good
This is a caption for hearing impaired, grab remote! scroll down to captions, use right arrow 1,2,3,off when the cursor is flashing over the " off " press enter on the remote, that should restore the set. Some remotes have the captions on a separate button.
Mar 11, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Black solid square keep popping up on my screen
Get the remote, press menu, scroll down to captions, press right 1,2,3,off when cursor is over off press enter on your remote, that should get rid of the black box.
Feb 17, 2011 | JVC AV-27020 TV
How to solve log base 2....
  1. In MthIO, pressing the log key displays a template: the log function and two squares, one smaller and below the main line, and another, bigger square/rectangle on the main line.
  2. Use the down arrow to move cursor to the smaller square end enter 2 as base.
  3. Use the up arrow to move cursor to the bigger square and enter the number whose binary log you want to calculate.
  4. Close the right parenthesis.
  5. Press the [=] sign at the bottom right of the calculator.
MthIO is the default Input/Output format of the calculator. To set it
  • Press [SHIFT][MODE] to access (Setup)
  • Select [1:MthIO]
Aug 17, 2010 | Casio FX-115ES Scientific Calculator
My TV has a black square in the middle of the picture. How do I fix that?
Your screen is showing a black picture because the closed caption function has been activated. When this closed caption mode is turned on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
Thanks for using FixYa. A rating is appreciated if the solution has worked for you.
Dec 25, 2009 | JVC AV-32D305 32" TV
I get a black square in the center of my screen on all channels. How do I get rid of it
Look through the menus (on screen) for the Closed Captioning (CC) and turn it (select) off.
Oct 28, 2009 | JVC AV-32260 32" TV
Lone99star
Apr 03, 2009 | JVC AV-32020 32" TV
JVC AV32260G COLOR TV
try resoldering vertical ic pins
Apr 19, 2008 | JVC AV-32260 32" TV
Jan 27, 2008 | JVC AV-32020 32" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
