Question about GE Kitchen Ranges
What would replacement electronics for our GE Spectra cost?
We have a GE Spectra,What is F1?how do you stop it from beeping when it does it?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 07, 2011 | GE Spectra JBP78 Electric Kitchen Range
I have a GE spectra JBP2AWD (2002?) and the oven does not heat - but the stove top still works. Anyone have any ideas or where we can find a manual?
Heating element is probably broken. You can use a continuity tester to see if yours is damaged. You can look at them and see if they are damaged, look for bends, cracks or breaks. Easy to replace, cost around $45.
Sep 28, 2010 | GE Profile Spectra JBP48 Electric Kitchen...
I have a ge profile spectra electric range not sure of model when i use oven tocook when i shut off oven a error F1 and continue with a beeping noise until oven cools down
Hi
Thanks for using FixYa. F1 error means that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | GE Profile Spectra JBP95 Electric Kitchen...
GE Profile Spectra F 0
Hi
Thanks for using FixYa. Error code F0 indicates failed thermistor/transistor in control. To resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 27, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
I have a 7 year old GE JBG910 gas convection oven. It recently started having a problem with the keypad. Certain numbers in the numeric portion of the keypad will not work and or beep. I an currently...
This sounds like the key pad needs replacing. The key pad is usually has a self sticking adhesive that secures it to the erc electronic range control. This is easy to replace. Try this link it should help http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | GE Profile Spectra JGB910 Gas Kitchen...
Does GE Spectra JBP68 have a fuse? Only 1/2 of range is working.
Your GE Spectra does NOT have a fuse, but it has a electronic control board, as well as elements. If both your elements heat up at all, then they are good. If you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service we can discus the issues with your range and I will attempt to get you back up and running again soon.
You may contact us from 7 AM until 9 PM CST Monday through Saturday for appliance assistance and parts.
We look forward to working with you.
Nov 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
