Question about Miscellaneous
Having trouble ordering with poimts - Miscellaneous
I oput aorder in this pm ,your having trouble with payment
I'm sorry, but Fixya has no mail order. Perhaps it might be more useful if you were to contact the vendor.
Feb 13, 2015 | Computers & Internet
Tip
How to keep your car below boiling poimt. ALL CARS!!!
most times in the heat your cars cooling system can over load, to stop overheating, always check your vehicles radiator water never the overflow resevoir.
always make sure your top radiator hose is hot, when running and your thermo fans come on automatically when on average heat temp. (half way).
make sure you cannot hear any noises ( clunking, grinding etc) from the waterpump, and always make sure you dont see water leaking from the vehicle ( except when air con is on).
if you do spring a leak always get it repaired ASAP as delay may further damge your cooling system, eg, head gasket and or head, effects may be warped, bent or cracked cylinder head.
always check your radiator and top up if needed at least ONCE A WEEK to avoid damage. and keep your overflow resevoir kept on the correct level.
cooling system failure can produce a big effect on your engines running capability and also your wallet!!!!!
keep your car cool in the heat!!
and also note, coolant or anti freeze does not keep your car cool, it is a corrosion inhibitor and only prevents corrosion and muck in and around your cooling system, your thermo fans keep your car cool!!!!
on Dec 04, 2009 | Acura CL Cars & Trucks
I'm having trouble getting the correct firing order for my 1995 vs Statesman any help would be appreciated
Any v8 308 holden motor has the same firing order so any manual will give you the order and the direction that the rotor button spins. It is 12784563 with 1357 being on the drivers side and the distributor turning clockwise. If you have a 253 v8 type in firing order for holden 253 v8 in google search and you will get even more information. If you have the original inlet manifold the piston order is stamped in the casting
Aug 03, 2013 | Cars & Trucks
Brand new gun seems to be in good working order,
If nothing is jammed the the hammer that hits it is probably not hitting could be bent,you can try cleaning and putting about 1/2 load in it .if not shouting then it isn't in good order / if new way not return should be warranty/defect
Mar 20, 2010 | Air Tools & Compressors
What is fireing order on 95 gt mustang gt/gts caneryyellow auto
5.0
V8 Firing Order: 1 3 7 2 6 5 4 8 Distrib. Rotation Is Counter Clock Wise
3.8
V6 Firing Order: 1 4 2 5 3 6
1 2 3
5 6 4 <<<<< Ignition Coil Pack Plug Wire Order
Feb 09, 2009 | 1995 Ford Mustang
Check engine light is on i have a 98 c230 and a 99 ml320 mercedes, both have "check engine lights" on. both run just fine. any ideas? thanks
Hi klapperkiste,
First you will need a generic obd2 reader in order to see what codes are stored in the ecm. If I'm not mistaken autozone will check it for free and give you a code like P0453, P and 4 digits #s with this information you will know what area the trouble is located. Still some testing will need to be done in order to pinpoint the trouble. It is very important that you write down all the DTCs (diagnostic trouble code)s in order to find the solution to your problem.
The "Check Engine" light will turn on when emissions out of the tail pipe exceed 1.5 times the federal limit. Any number of thing can cause the light to come on and not show any driveability symptoms, a common cause is leaving the gas cap loose after a fill up. I hope find this information helpful, More information is needed on your part to go further in finding a solution to your problem.
Nov 23, 2008 | 1998 Mercedes-Benz C-Class
1909 buick skylark tps low volts trouble code
replace ignition coil make sure by dealer the right mode is used when ordering if not ordered right you will get a difference in engine volts
Jun 07, 2008 | 1991 Isuzu Pickup
Trouble ordering part LSUQ0100 JIG
You need to be an authorized panasonic service center to get that item.
Apr 10, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Trouble finding part LSUQ0100 JIG
This item is normally only on backorder for 5 days. However, not many store are able to stock this part as it needs an authorization number to order this. You can only obtain an authorization number from Panasonic Tech Support.
Apr 06, 2008 | Televison & Video
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
