Question about Building Materials
Door will not shut with remote when it is cold,,,will open
Remote start engine shuts off when you open the door
sounds like the kill switch was wired to the door instead of the brake switch.
Feb 23, 2014 | 2014 Mitsubishi Outlander Sport
My garage door will only open half way. It appears to be getting stuck when it is opening.
If you haven't gotten your issue fixed yet... I had the same problem (stopped opening half way when using the remote, went down fine, could lift/close manually fine as well) and this happened on our first cold weather day of the year which was very telling. Anyhow, there are two gauges/dials on your garage door opener unit itself (above, where the light is) which controls how much torque/strength your door uses to open or shut through resistance. I turned mine up some and it now works fine; what likely happened was that the metal tracks or the wood frame condensed in the cold and was providing just enough resistance to stop it when opening - as they have a security device built in to stop if they meet any resistance. Hopefully this helps!
Oct 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Oct 20, 2012 | Home Security
Our toyota is beeping and will not open with either the manual key the remote
Have you had cold weather latly or is it below freezing there by chance? I read somewhere that toyota siennas doors freeze shut constantly and make it seem like the keys wont work.
Dec 22, 2010 | 2007 Toyota Sienna
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
We live in a cold state (MN) and this year though it hasn't been incredibly cold our 2000 Kia Sephia constantly freezes shut. The power door lock on the driver side won't move from the inside or the...
part of the problem with being in such a cold place is even tho its so cold there is still moisture in the air. if you door wont close or open, you need to check the latch out and make sure its not just bent. as for not being able to unlock you door. the latching system is connected to the lock and handle. if the latch wont move don't use wd-40 that will make it worse. you need to pull open the door panel and get it greased with a grease gun. wd-40 will not keep the parts moving in that kind of cold. if latch wont reset
when you get it open, it wont close. just grease it up. oh it would help if you get water guard for your windows. protect you parts from freezing. take care.
Feb 22, 2010 | 2000 Kia Sephia
Building Materials Logo
50 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
