Question about Siemens Washing Machines
My Siemens ovan . Microwave seems to have an earth leakage problem as it trip my fuse board
  • 21 Answers
SOURCE: Shutdown of DW very near end of drying cycle
good to hear that you got this fixed.
Posted on Jun 10, 2008
  • 832 Answers
SOURCE: onga smh45 tripping rcd
Check the electrical connection for grounded wires or
loose electrical connections. Use wire nut for all electrical connnection and tape it properly. This should
correct the 20 ohms earth leakage. Send you e-mail comments for further assistance.;
Posted on Oct 27, 2009
SOURCE: Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
Posted on Dec 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: when I switch on my
It appears your timer/control board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer working fine, fridge not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
When I plug in (and switch on) the hostess trolley it trips the electric in the house. However, works perfectly in another house.
sounds as if your home power distribution / Fuse board has an earth leakage trip and is sensing a leak on the trolley, perhaps the other house is not so well protected, or the Earth Leakage Circuit Breaker ( ELCB) trip is faulty. It would make sense not to use the trolley until you have had it checked out
Jan 02, 2016 | Televison & Video
Hi, we have a Bosch HMT8656GB built-in microwave, and the other night (shortly after microwaving several potatoes), it shorted out and tripped the main fuse for the kitchen sockets. We've isolated it to...
Confirm that the receptacle where the microwave is plugged in is not faulty by plugging something else in the recepticle and seeing if it works or if the fuse blows. Check the power cord of the microwave for broken, frayed wires. Also check the bulb socket for broken wires. It may or may not be worth the cost of repair, depending on the repair cost verses a new microwave. There are repair parts available.
May 08, 2014 | Bosch HMT8656GB Microwave Oven
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
My Defy 621 stove causes the earth leakage to trip after a few minutes when the oven is swithed on. The thermostat was resently replaced. Could it be one of the elements, although it seems they are...
Most likely an element. When the heating wire expands inside the tube it contacts earth and kicks out the earth leakage. Select 'grill' and try the oven. If it does not trip out the lower element is the culprit. Replacement is easy for a reasonably adept handyman - just make sure that the mains are off!
Jan 16, 2011 | Ovens
When using the oven portion of the microwave oven it continues to trip the circuit the microwave is alone on a 20amp circuit .When I microwave it doesn't trip at all.Is it possible to move up to a 30 or 50...
If the breaker is an earth leakage type, it is possibly an earth leak problem which could be caused by insulation breakdown on the heater inside the microwave.
I would consult an aporved electrician for advice.
Jan 04, 2011 | Microwave Ovens
Our lg microwave Model LMVa925SB seems to cut out when starting it all the time and we have to reset our outside power switch. My husband changed the switches as told by a home depot person to another...
You may have an "Earth Leak". That can be caused by, in microwave ovens, spilliage on the turntable motor causing a "leak of mains power" to Earth and tripping the RCD switch.
Have a look at the motor from underneath where the inspection cover can be removed.
Or
a leak from within the appliance itself due to leakage of boiled over/steamed food. It is clearly not safe to use as it is.
Dec 22, 2010 | LG Microwave Ovens
Motherboard dies after earth leakage trips
By the time you need to replace the "new" spare motherboard it will probably be time to upgrade anyways.
I say just swap it out and keep that old board tucked away for a rainy day.
Dec 06, 2009 | Computers & Internet
May 02, 2009 | Siemens Ovens
Looking for contol board
Please contact the repairclinic.com
Nov 21, 2017 | Estate Microwave Ovens
Washing Machines Logo
24 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
