Question about Dehumidifiers
IDYLIS dehumidifier, ITEM #0526011 being recalled ?
Idylis dehumidifiers. Any recalls?
U can find out here: https://www.cpsc.gov/Recalls/2017/Gree-Reannounces-Dehumidifier-Recall-Following-450-Fires-and-19-Million-in-Property-Damageb
Mar 23, 2017 | Dehumidifiers
Idylis dehumidifier 0526011 will not shut off even when is reaches it humidity level. How can I get it to shut off. The compressor stops but the fan keeps running.
this is a newer feature that a lot of units do now this is called air circulation mode !! try running on low it's not so noisy then
Oct 03, 2014 | Dehumidifiers
How do you set on and off auto
See page 7 on the user manual to set the humidity level and the unit will then operate within the set humidity range. You can also set the timer to make it shut off automatically after a specific time. You may also need to install the continuous drain feature if you do not want to empty the water tank repeatedly.
http://pdf.lowes.com/useandcareguides/840206120030_use.pdf
Aug 06, 2014 | Dehumidifiers
Need manual for idylis 0526011
here is the manual: http://pdf.lowes.com/useandcareguides/840206120030_use.pdf
Jun 16, 2014 | Dehumidifiers
Idylis 0526011 does not work
SET IT TO LOWER SETTING
Mar 07, 2014 | Dehumidifiers
Dehumidifiers Logo
131 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
