Lost the curser... its one ********* square, not the little arrow
I get lots of little squares you can see the result but behind theres alot of little squares
The calculator belongs to a new generation of scientific calculators that enjoy the feature called MathPrint by TI, Natural Display by Casio, and WriteView by Sharp
When the calculator is configured to work with this Display you are shown a template as you would see on a textbook. The squares are the places where you enter the numbers. For example when you press the fraction key the calculator displays a the picture of a stacked fraction with one square on either side of the horizontal fraction bar. The square where the cursor is located and blinking appear dark. You start entering the numerator there, then you use the down arrow to move to the denominator. When fraction is finished you move the square away from the fraction to the main line using the right arrow key.
I hole this solves the annoying problem of the mysterious squares.
Please read the manual to learn about this feature so that you can decide whether to take advantage of it or not.
Feb 19, 2013 | Casio fx-300ES Calculator
My acer laptop curser only moves with the arrow keys, it just started doing that. what happened?
on your laptop there is a key to lock the touchpad - may be its turned off for some reason - give a check - belive the f6 or f7 key (picture of a square with a finger) press the Fn ( bottom left on keyboard ) hold it and press with f6 or f7 (find the picture) . it will enable the touchpad - give a try
Oct 04, 2010 | Microsoft Windows Vista Ultimate Edition
I have little squares of different colors on my monitor it also seems like my cpu isn't fully booting up. I changed wires and nothing changes I can't see anything so I can't download any virus protection...
try to boot in safe mode by pressing F8 when you turn on the computer use the up/down arrow key to highlight safemode and press enter press enter to select your OS then wait until it loads. during boot up if it still shows the little squares try a known good monitor if it has the little square the video card is busted and needs to be replaced however if ever the known good monitor doesnt have the little square then its the monitor that needs to be replaced.
hope this help
Aug 16, 2010 | Dell Dimension 2400 PC Desktop
The numbers are not visible on the screen and Im not able to set the calculator on the degree mode .
First try this- press the 2nd key and press and hold the up arrow key or the down arrow on the right side of the calculator a for a few seconds and see if the curser appears - if it does - than problem solved . to set the calculator to degree mode press the MODE button and find Radain, degree and hightlight it by moving the curser over it and press enter than exit it now set to degree and press sin(30 and enter and see if you get .5 as a result it it does than problem solved
Oct 06, 2009 | Texas Instruments TI-85 Calculator
Lost curser
Make sure that the sensor bar has an uninterrupted clear connection with the Wii remote.
Aug 08, 2009 | Nintendo Wii Console
I turned off my curser and mouse pad by mistake and i cant type use the curser to get into control panel
Press the Windows or Start button on your keyboard, and use TAB, or your down arrows to move to the Control Panel. Use Enter to make a choice, until you get to the cursor.
Jul 20, 2008 | Acer Computers & Internet
Vivitar 3720 digital camera
,,,push the "square" button in the middle of the direction arrows. the right arrow across untill you come to Date and Time the down arrow to select the "set" and press the square button again
....use the up and down arrows to select the correct date
....use the right arrow button to set the month and day and so on.....
Also, if you don't want the time displayed on the picture, just select "no display".
I hope this helps!
Aug 12, 2007 | Vivitar ViviCam 3720 Digital Camera
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
